local stock block class
we have a local class called stock block, its a fun class with certain rules , there is 3 classes , NA-PA- BI(natural aspirated-- power adder--big inch) the na and pa class are 360ci or smaller, the BI class is 470ci or smaller..small block can run aftermarket heads and big blocks have to run factory heads, all cars 10.5 or smaller tires, no ladder bars 4 links, i finished 3rd in points, was 1# qualifier 1 time went the the finals 2 times, we had the last race of season this past weekend in mokan , i went the the finals and brung home $290
i have most of the field covered in my class (BIG INCH)JW timmerman has a fast BBF mustang and is faster then me,(393w small block) my car does well for having the smallest motor in the class and smallest tire on bone stock suspension, i feel if i had full race suspension on my car i could hung with him, he runs 10.40-50 range(450ci) ,I had a absolute blast in this class, here is the final race between jw and me, i am in the silver car
johndickjr- Posts : 896
Re: local stock block class
Nice working Fairmont John!!
What do you have done suspension wise? What tire size do you run?
Bill
Bill
billandlori- Posts : 2081
suspension = 100% stock , i did put some polyurethane bushings in , im on 8.5 tiresbillandlori wrote:Nice working Fairmont John!!
Bill
Sorry, I see its a Zephyr lol!!
I'm starting to get my 80 Futura set up for next spring. Going with my big block out of my T-Bird. Seeing how yours works gives me a lot of hope!!
Bill
Bill
its a zephyr, the hood , passenger door and fender are fairmont , small fender bender from previous owner, i have not really tried much as far as jets and stuff, it runs consistent i hate to jack with it,20 passes now and not a single issue ran 10.91 3 times in a row then a 10.88 and 6.86 with 1.48 60ftbillandlori wrote:Sorry, I see its a Zephyr lol!!
Bill
From what I got out of what you are doing, you are doing it well.
A 414 "Clevor" would be the way to go with those rules you've posted.
rmcomprandy wrote:From what I got out of what you are doing, you are doing it well.
Randy, why a 414 over a 427 "Clevor" I get the Alum head and RPM advantage but...I am guessing it has to do with when and how the low end torque comes in to play with the suspension woes? and guessing you already have the blueprint
And for the PA class a worked CJ headed 466" -469" with a progressive controller and a DP kit?.
FalconEh- Posts : 1448
the B.I class is a all motor class, we can use a Cleveland head but has to be factory ironFalconEh wrote:rmcomprandy wrote:From what I got out of what you are doing, you are doing it well.
johndickjr wrote:the B.I class is a all motor class, we can use a Cleveland head but has to be factory ironFalconEh wrote:rmcomprandy wrote:From what I got out of what you are doing, you are doing it well.
I thought you said that B.I. small block engines could use aftermarket heads ... I am guessing that rule is only applicable toward SOME small blocks.
Getting more than a 4" stroke in a small block would only add torque by having a lower limit on RPM, not much more horsepower, if any.
we can use aftermarket heads that are aluminum or cast iron or we can use a Cleveland head but it has to be a factory iron head, no aftermarket Cleveland style heads on the sbfrmcomprandy wrote:johndickjr wrote:the B.I class is a all motor class, we can use a Cleveland head but has to be factory ironFalconEh wrote:rmcomprandy wrote:From what I got out of what you are doing, you are doing it well.
» My local track has added a 10.5 non W, heads up class at todays race
» Lookin For NHRA Stock Class ET/MPH from 1970-71 era
» question about stock 1971 stock block
» Differences between stock type block and the a460 block?
» Engine block class limitation
