533 Big Block pump gas turn key
Post  jgreene70 on September 26th 2015, 12:33 pm
Listing the engine separate from my car.  Going to see about keeping the car and converting it.
D1VE block.  Machine work done by Rickman Auto parts in Rickman Tn
Assembled by a local builder Stacey Cash
Been together approx 6 yrs. Little run time due to lack of time after was built.
Scat Forged bottom end kit, with Forged H-beam rods and JE dish pistons.  9:8.1 comp
Neutral balanced
Summit SFI balancer with billet 2 groove pulley and alumn spacer sleeve
Moroso electric water pump
FRPP 90* oil filter adapter
SCJ-B heads. Changed springs last winter, along with retainers,  keepers, custom ground Comp cam from Lem Evans
Comp Cams solid roller Lift Int/Exh .683/.683 Duration .050 int 260 exh 268  110 lobe seperation. Specs are for 108 installed centerline.
Herbert solid roller bar lifters
3/8" pushrods manly and trickflow
Harland Sharp 1.73 rockers clearanced slightly for the retainer.
Jomar stud girdle
Canton deep front sump oil pan wit windage tray and pickup
Melling HV pump
CLoyes adjustable timing set.
Mafia intake.
New last year MSD distributor
Moroso wires.
also have Hitachi starter if wanted.
This is complete running engine.
Located Albany ky  can call or text 606-306-5260
$7800 turn key
$10 Trans and total package.
T56 XL magnum trans setup.
http://illiweb.com/fa/pbucket.gif4
Last edited by jgreene70 on October 3rd 2016, 11:52 am; edited 6 times in total (Reason for editing : change price)
jgreene70
jgreene70
Re: 533 Big Block pump gas turn key
Post  jgreene70 on October 8th 2015, 9:30 pm
open to offers. Need this to go so can free up funds for suspension.
jgreene70
jgreene70
Post  jgreene70 on October 19th 2015, 7:07 pm
Lets try $8000
jgreene70
jgreene70
Post  jgreene70 on November 15th 2015, 4:52 pm
$7800
jgreene70
jgreene70
Post  jgreene70 on December 15th 2015, 8:35 am
$7500 final drop have too much in it to give away
jgreene70
jgreene70
Post  jgreene70 on January 12th 2016, 11:49 am
Bump for the new year.
jgreene70
jgreene70
Post  79ford pickup on January 12th 2016, 1:50 pm
The chassis not for sale.
79ford pickup
Post  jgreene70 on January 12th 2016, 2:29 pm
I would consider selling the chassis. I had the entire car listed. But my goal of the ending sells Going to redo front suspension. Drop in a coyote or sbf, partnered with a t56 and eventually convert it to more of a pro touring auto cross setup.
jgreene70
jgreene70
Post  jgreene70 on January 26th 2016, 8:26 am
Turn Key including the Hitachi starter $8200
With powerglide trans 1.98 planetary, pro tree brake, roller tailshaft, deep pan, boss Hogg converter JW bell housing and wheel  $10,000
jgreene70
jgreene70
Post  jgreene70 on February 11th 2016, 9:10 pm
Prefer not to sell trans separate unless have a commitment on the engine
jgreene70
jgreene70
Post  jgreene70 on February 22nd 2016, 9:08 pm
Put battery on and started the ole girl up last weekend.
jgreene70
jgreene70
Post  jgreene70 on March 14th 2016, 9:55 pm
Open to offers
jgreene70
jgreene70
Post  jgreene70 on March 25th 2016, 8:04 pm
jgreene70
jgreene70
Post  jgreene70 on April 16th 2016, 9:22 am
$7800 carb to pan. (turn Key)
I will keep from flex plate back. You get water pump, starter, plugs, wires, 90* oil filter adapter, all. I will keep my radiator hoses and filler neck.
Buy responsible for pickup at this price.
jgreene70
jgreene70
Post  jgreene70 on October 3rd 2016, 11:51 am
jgreene70
jgreene70
Post  James Hahn on October 11th 2016, 9:39 pm
jgreene70 wrote:Listing the engine separate from my car.  Going to see about keeping the car and converting it.
Neutral balanced
Jomar stud girdle
How much HP does this engine have?
Melling HV pump
Mafia intake.
Moroso wires.
$7800 turn key
James Hahn
Post  jgreene70 on October 12th 2016, 7:43 am
Have not dyno'd this engine. Should be 650-700hp. I talked to a shop 2 weeks ago. They will chassis dyno and tune it for $250
jgreene70
jgreene70
