Water injection???
Page 2 of 2 Previous  1, 2
Water injection
Post  blown473 on March 4th 2010, 6:02 pm
I will try and take some pics and post them. The brass tubes have very small holes in them, it injects more like a mist than a squirt. I just changed the activator from the throttle linkage to a button on my hurst shifter handle, my trucks a 4 speed this allows me to activate it at any throttle position also. I'm surprised more people don't use these systems, as they are proven and have been around forever. A simple home built kit can be done with wrecking yard parts. It might not be a fancy as the electronic ones on the market today, but will still be very effective. Greg Very Happy
blown473
Re: Water injection???
Post  77f150 on March 4th 2010, 6:14 pm
If you do some general searches with google you'll find articles on building homemade units. As well if you have the money to spend there are several good manufactures with purpose built kits that have adjustable boost referenced programers. The only thing I would recommend is a decent size tank for your water/methanol, the little bottles they supply will last one tank of gas at best.
77f150
more on water injection
Post  blown473 on March 4th 2010, 7:03 pm
A good size tank is a plus, and keeping the water/alky as cool as possible helps, so find a good location. I have a truck so I put a 2 gal aluminum "Moon "tank back there, coated the inside to deter the alky corrosion, (not necessary with a plastic tank). You can take a long trip with this set up.
blown473
Post  rodknox302 on March 8th 2010, 10:29 pm
I've ran water methanol injection with nitrous. You basically tie it right into the nitrous system so that when you fire off the nitrous you activate both the water injection and nitrous. The water injection doesn't burn as someone was mentioning earlier. Yet it does slow down the burn rate of the fuel, giving you a more controlled burn, essentially acting as an octane enhancer and helping to eliminate chances of detonation. Check out this new kit by AIS.
http://www.alcoholinjectionsystems.com/p101/Stage-1-Competition-Trunk-Mount-Water-Methanol-Injection-System/product_info.html
rodknox302
Post  511Fox on March 9th 2010, 3:53 pm
RodKNox302,are you feeding the engine Straight Methanol + Water or Window Washer fluid Question
This thread is Boss Exclamation
I think N2O has evened the playing field with Turbos & Centrifugals.
511Fox
Post  rodknox302 on March 9th 2010, 4:42 pm
511Fox wrote:RodKNox302,are you feeding the engine Straight Methanol + Water or Window Washer fluid Question
Im spraying -20 washer fluid (30% methanol) so it doesn't effect air fuel much at all. No need to change fuel jets on the nitrous side. Plus, if the water methanol injection didn't fire off your not losing any of your fuel.
rodknox302
-20 Window Washer Fluid
Post  511Fox on March 9th 2010, 4:47 pm
I bet this (-20 Window Washer Fluid) is easier to come by than straight Methanol Exclamation
RodKnox302 How much "Juice" you use'n Question
511Fox
Post  rddogoli on March 24th 2010, 6:38 am
I was wondering if this water injection system works with racing fuel like 116octaine, i see most the posts say methanol, isn't that actually alcohal not gas? just wondering, don't know much about this stuff.
rddogoli
fuels/water injection
Post  blown473 on March 24th 2010, 6:16 pm
Water injection and alky refer to mixing the 2 in the water injection tank. Both cool the intake charge, the alky adds some octane too. As for your engine you can power it on what ever you want, gas, alky, propane, diesel , race gas, whatever... Very Happy
blown473
Post  bruno on March 30th 2010, 4:47 pm
here are some good tech reads from that same site
http://www.alcoholinjectionsystems.com/Tech-Articles/t7/articles.html
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
