514 stroker
514 stroker Empty 514 stroker
Post  jilinda on November 6th 2015, 6:45 pm
best plugs for a jet boat? It runs at 3200 - 4000 in short 8 0% of the time.Max rpm is 4500 in short runs.500hp&600# tq,9.5:1,hyd roller cam ,eagle rotating ass.91 oct non ethanol fuel.Will sometimes run it for an hour at a time at 32-3400 rpm without lifting on the throttle. thanks  JIM
jilinda
514 stroker Empty Tell us what heads you have
Post  manofmerc on November 10th 2015, 6:39 am
More info is required what are your heads ? Aluminum or cast iron early like doves or d3s .
manofmerc
514 stroker Empty 514 heads
Post  jilinda on November 15th 2015, 5:52 pm
I believe they are iron d3's,they have had some port work done on them. thanks,JIM
jilinda
514 stroker Empty Re: 514 stroker
Post  dfree383 on November 15th 2015, 6:21 pm
jilinda wrote:I believe they are iron d3's,they have had some port work done on them. thanks,JIM
Need to know for sure... "I believe" can get you the wrong stuff
Post  jilinda on November 15th 2015, 9:17 pm
I know they are cast iron,not positive on the doves or D3's
jilinda
514 stroker Empty 514 plugs
Post  jilinda on November 19th 2015, 3:56 pm
Got some help from a local bbf junkie locally.Decided to go with AR24 or 24 autolites.NGK BPR6FS also. thanks for the help
jilinda
