351w roller cam distributor?
Post  cheatham on January 11th 2016, 9:50 am
Thought that I seen where a 460 duraspark could be used with a distributor gear change in a 351w hyd. Roller cam? Is that right? Any heads up on this?
cheatham
Re: 351w roller cam distributor?
Post  rmcomprandy on January 11th 2016, 11:06 am
cheatham wrote:Thought that I seen where a 460 duraspark could be used with a distributor gear change in a 351w hyd. Roller cam? Is that right? Any heads up on this?
The main distributors can be interchanged but, the gears can not.
The 429/460 gear is the same as the 351 Cleveland and "M" engines; the Windsor gear is smaller.
Post  cheatham on January 11th 2016, 11:40 am
Thanks Randy. If I'm understanding right, the difference is the gear, so press the 460 gear off, and replace
With the 351w gear.
cheatham
Post  jbozzelle on January 13th 2016, 10:00 pm
Yep. Make sure to install it at the correct height too.
Post  cheatham on January 13th 2016, 10:43 pm
Thank you guys
cheatham
Post  gt350hr on May 2nd 2016, 3:29 pm
You can use an '87 up 5.0 gear on the 351W or 429-460 dist, as well.
gt350hr
Post  whitefield on May 2nd 2016, 5:27 pm
gt350hr wrote:     You can use an '87 up 5.0 gear on the 351W or 429-460 dist, as well.
No sir says I ! 302, 5.0 and 289 have a smaller distributor shaft than the 351W 351C 429 and 460. 351m 400 to .However you can interchange the 351W with the 351C ,351m ,400 ,429 and 460 by changing the gears
whitefield
Post  whitefield on May 2nd 2016, 5:28 pm
cheatham wrote:Thanks Randy. If I'm understanding right, the difference is the gear, so press the 460 gear off, and replace
With the 351w gear.
Yes if you are using it in a 351W/5.8
whitefield
Post  gt350hr on May 9th 2016, 6:38 pm
    Yes the "early" distributors have a .467 shaft that is correct. I was careful and said "'87 up". THOSE gears have the common .531 i.d.. I KNOW it can be done because I did it. A simple check of the Ford Racing catalog will confirm it.
   Respectfully.
gt350hr
Post  gmsmkr on May 9th 2016, 7:00 pm
scratch
gmsmkr
Post  rmcomprandy on May 9th 2016, 10:38 pm
The later 5.0 liter F.I. distributors I have seen have a 531" shaft stepped-down to .467" below the gear.
They are NOT Duraspark magnetic impulse distributors; they are Hall affect trigger meant for the F.I. "Thick film" ignitions.
ANY, 302 / 5.0 liter distributor gear is to small for any big block Ford use but, the same outer diameter as a 351W.
Post  gt350hr on May 11th 2016, 4:07 pm
.531 is still .531 be it a 429-460 or 351-400 or 351W or '87 up 5.0 with a major shaft diameter of .531. Yes I know the "pilot hole" in the 5.0 block is smaller @ .467 and the 5.0 shaft is stepped , but the gear is still .531. The roll pin height is different from the W location to the 351C-460 location so you drill a new hole . I have a Ford Motorsport 460 dist. with a 5.0 (.531 gear id) which makes it a 351 W roller distributor. 5 years of daily driving and zero problem on an F302 cam and 1.7 Cobra rockers. Check an older Ford Motorsport catalog for the details. ( 2002 and earlier). It's all there in black and white.
gt350hr
Post  whitefield on May 11th 2016, 7:12 pm
I should have stated it this way and I do realize I put 5.0 out of habit . A 302 duraspark distributor from 302 to 351w are not the same shaft diameter or gear . I understand my error in the way I Stated it in my earlier post. Embarassed
whitefield
