408w rpm air gap or victor jr intake
Post  cheatham on January 15th 2016, 1:06 pm
I have a 408w 9.5 compression
Tfs stage 3 hyd roller cam .236/.248 575 ish lift 110ls roughly
63cc home built procomp 210 with 2.05 int 1.60 ex
Had em built and ported by Eric wiengardner in Tulsa
They were 10 cfm down at .600 from victor jr head on intake.
Anyway I know these ain't the best heads but it's what I have.
My question is, I have an Edelbrock rpm airgap, and an edelbrock vic jr intake
850 holley dbl pump carb
Which intake sounds better to use?
Not sure what I will put this in..probably a fox body mustang
Or my wifes 2003 mustang gt when she wears it out..
More then likely just sit on the engine stand a few more years,
Just wanting to finish it up and seal it up with the intake
Thanks again
cheatham
Re: 408w rpm air gap or victor jr intake
Post  gmsmkr on January 15th 2016, 6:21 pm
Air gap gets my vote with a set of 1-3/4 headers
gmsmkr
Post  cheatham on January 15th 2016, 7:42 pm
Thanks.
cheatham
Post  johndickjr on January 15th 2016, 8:57 pm
vic jr , these bigger small block love bigger intake even with low compression and a small cam, 408 cubes with that cam and a dual plain intake will be dead at 5500 rpm, vic jr will get little rpm out of it and move more air, i have a 393w and im using a fully ported super vic intake on mine
johndickjr
Post  rmcomprandy on January 15th 2016, 10:11 pm
johndickjr wrote:vic jr , these bigger small block love bigger intake even with low compression and a small cam, 408 cubes with that cam and a dual plain intake will be dead at 5500 rpm, vic jr will get little rpm out of it and move more air, i have a 393w and im using a fully ported super vic intake on mine
I guess you better check my last 414 Windsor Engine Masters entry.
There's a link to it somewhere in here.
A port matched "Air Gap" will make more horsepower right up to 5,500 RPM but, it doesn't simply die there. And, a lot more torque below that RPM. Especially with 9.5/1 compression ratio.
Post  johndickjr on January 15th 2016, 10:34 pm
he did not say he has a port matched intake, im sure a ported match intake will make more power
johndickjr
Post  cheatham on January 15th 2016, 11:14 pm
I'll put the air gap on it. Thanks for y'all help
It will be awhile before I run it but need to get it sealed up and shrink wrapped
I'm gonna check out your 414w Randy.
cheatham
Post  rmcomprandy on January 17th 2016, 1:42 am
Just for everyone's information, when I actually compared their power to one another on the dyno, the Victor Jr. was also ported.
Both manifolds come with the same size ports at the flange which is smaller than the Ford Racing M-9439-A50 intake gasket which I use.
Post  johndickjr on January 23rd 2016, 11:51 pm
rmcomprandy wrote:Just for everyone's information, when I actually compared their power to one another on the dyno, the Victor Jr. was also ported.
how much power difference was there between the 2 and what about rpm ? i may have to try one out
johndickjr
Post  rmcomprandy on January 24th 2016, 12:57 pm
The Victor Jr. was 24 horsepower better at peak power but, worse everywhere below 6,000 RPM.
Peak power with the "Air Gap' was 6,700 RPM and peak with the Victor Jr. was 7,000 RPM.
We were forced by rules to use the "Air Gap" but, I wanted to see what the differences were.
I have a Super Victor to try but, never did because I saw no point here at this RPM level when the target and the rest of the engine is built for 3,500 to 6,800 RPM.
Post  dfree383 on January 24th 2016, 2:13 pm
Street car with a tight convertor and highway gears use the dual plane.
Street strip car with a loose convertor and some digger gears use the single plane
Post  cheatham on January 24th 2016, 4:34 pm
Probably a stree car deal, just a engine stand deal for a few more years really
She likes her litte 4.6 mustang and while it ain't no power house its a good
Little work car.
I bought the parts 8 yrs ago..someday though
cheatham
Post  johndickjr on January 24th 2016, 6:22 pm
i shift my 393 at 6500, so i am wondering it it would pick any et up, never tried any higher, car runs where i want it to (6.60s)so i didt see any need to push it harder currelnly running a fully ported super Vic
johndickjr
Post  gt350hr on February 2nd 2016, 1:39 pm
I have the air gap on my 408. 9.7cr Ford X305 heads , NO porting and Ford X302 hyd roller. 735cfm CJ vacuum secondary carb. 480 hp - 525 tq revs to 7,000 with the "HR" Ford lifters. 1-3/4 long tubes , 87 octane gas , 34* total timing. Except for being cold blooded on initial start up , I like the manifold.
gt350hr
