Header size ?
+8
johndickjr
gmsmkr
whitefield
12 posters
Header size ?
Suggestions on header size for a 408W with 205AFR heads and 13.1 compression solid roller cam max rpm 7500 Vic jr intake and 950 carb. 1"7/8 or 2" primary tube headers ?
whitefield- Posts : 2243
Re: Header size ?
1 7/8 headers belong on a motor with 10.1 comp ..... not a 13.1 408w in race trim
gmsmkr- Posts : 1364
Re: Header size ?
whitefield wrote:Suggestions on header size for a 408W with 205AFR heads and 13.1 compression solid roller cam max rpm 7500 Vic jr intake and 950 carb. 1"7/8 or 2" primary tube headers ?
If that engine ever drops below 6,000 RPM use the 1 7/8" primary tubes. Above 6,800 RPM will be the only place the 2" tube will be better.
Re: Header size ?
NA, the 1 7/8" will probably be faster but the 2" will make more power. With those heads.
whatbumper- Posts : 3024
Re: Header size ?
Long tube headers I would assume ...with a N/A combo at 7500, guessing 3" or 3 1/2" collector with a min. 3" exhaust or no exhaust, I would use the 1 7/8" ...if you want to spray it use the 2". The heads will flow more but like Randy said 700 RPM is not the majority of the pass when you limit it to 7500.
FalconEh- Posts : 1448
Re: Header size ?
rmcomprandy wrote:whitefield wrote:Suggestions on header size for a 408W with 205AFR heads and 13.1 compression solid roller cam max rpm 7500 Vic jr intake and 950 carb. 1"7/8 or 2" primary tube headers ?
5000 stall . I limited it to 7500 rpm due to having a stock 74 block . I thought about turning it on up to 7800 or 8000 RPM. NA engine.
Re: Header size ?
I ordered the 1 7/8 with 3" collector long tube kooks headers . Thanks for all of the replies!
Re: Header size ?
That video is a hoot and a shocker.
maverick- BBF CONTRIBUTOR
Re: Header size ?
maverick wrote:That video is a hoot and a shocker.
& easy hp. lol
res0rli9- BBF CONTRIBUTOR
Re: Header size ?
cousin had a vega with a decent 406 sbc in it, it had 1-1/2 tubes, ran 11.00, finally got some big hp building tubes for the car , thinking the was lemons maybe, like $1000, 1-3/4 or 7/8 tubes, merge collector , all the tricks..car ran 11.00 after wards, my headers are my car are beat to shit, 1-3/4 it runs 6.60s, maybe ill dent it some more
johndickjr- Posts : 896
Re: Header size ?
Oh hell, next someone will say single pattern cams are good.
supervel45- Posts : 4452
Re: Header size ?
supervel45 wrote:Oh hell, next someone will say single pattern cams are good.
Everything has its application........ most build with their wallet not their brain.
Re: Header size ?
how bout a stepped header, 1-7/8 into a 2"...?
torino501- Posts : 417
Re: Header size ?
johndickjr wrote:
I'd rather have a maple syrup enema and sit on an ant hill then deal with David Freiburger on a daily basis!
wickettoby1- Posts : 352
» Header Size?
» Header size
» Header size ?
» Header Size?
» What would be the best size header for my combo ??
» Header size
» Header size ?
» Header Size?
