Boss 429 cam help
rmk57
Re: Boss 429 cam help
rmk57 wrote:rmcomprandy wrote:supervel45 wrote:http://www.summitracing.com/parts/cca-cl33-246-4/overview/make/ford Here is the link.
What amount of valve lift will your valve springs allow...?
That's a good question. I also don't know what piston to valve clearance would be with that cam either.
The engine has been balanced, ARP rod bolts, headers, 850 Holley, that pretty much it.
90% of these cars are pushed on and off trailers at car auctions so there's not much info on
Any kind of performance mods for a stocker. The builds you see in magazines are usually Kasse strokers that aren't much use to me.
If you don't know those things then I would have something custom ground to be near OEM lift and duration but, with a bit more aggressive lobe profile.
dfree383 wrote:BOSS 429 wrote:come on guys, .570 lift - .036, ratio -.018 or so for lash, then head growth= about ,510 lift or so, stock boss 429 cam is .508 lift
and the dur would be lost as well
The factory Lobes are nowhere near as aggressive and its a stock B9 not a race car. I'd bet the modern cam is worth at least 20-30hp and would still be nice and drivable.
never had race car in mind, I just want it to run good for the op
BOSS 429- Posts : 2365
I could mock the engine up with the stock cam and check p2v clearance.
That should show me what I could get away with, right?
rmk57- Posts : 170
rmk57 wrote:I could mock the engine up with the stock cam and check p2v clearance.
Yes...It may be off topic but it sounds like the heads are off...do they have hardened seats?
FalconEh- Posts : 1448
FalconEh wrote:rmk57 wrote:I could mock the engine up with the stock cam and check p2v clearance.
They come with stellite seats from the factory, so your good to go with unleaded fuel.
rmk57- Posts : 170
It should give you a good idea.rmk57 wrote:I could mock the engine up with the stock cam and check p2v clearance.
supervel45- Posts : 4426
» boss fords boss 429 scj /cj's boss 351
» Win this Boss 9 car!
» 632 Boss Nine
» 514 ci,
» Kaase Boss 9 Heads...
» 632 Boss Nine
» 514 ci,
