Lunati or comp cam ?
Lunati or comp cam ? Empty Lunati or comp cam ?
Post  whitefield February 17th 2017, 12:51 pm
Which solid roller lifters would be the better of these two to run ?
http://www.lunatipower.com/Product.aspx?id=837&gid=214
https://www.summitracing.com/search/part-type/lifters/brand/comp-cams/engine-type/v8/make/ford/engine-size/5-0l-302/lifter-outside-diameter-in/0-875-in/quantity/sold-as-a-set-of-16?N=4294925202%2B400114%2B4294951399%2B4294951343%2B4294951339%2B4294888300%2B4294943488&keyword=Solid%20roller%20lifters
whitefield
whitefield
Lunati or comp cam ? Empty Re: Lunati or comp cam ?
Post  rmcomprandy February 17th 2017, 9:44 pm
Those Lunati lifters are entry level Morel lifters.
Post  whitefield February 17th 2017, 9:47 pm
rmcomprandy wrote:Those Lunati lifters are entry level Morel lifters.
Thanks Randy . So I take it they are a good set of lifters for a 600 hp sbf ?
whitefield
whitefield
Post  rmcomprandy February 18th 2017, 12:36 am
I have used them for that but, kept the open valve spring pressure under 600 lbs.
