521” BBF - Pump Gas Street Motor
I started building this motor to put into my 65 Mustang a couple years ago. Unfortunately once I got the car out of body shop jail I found that even with the shock towers removed it will not fit in the car as cleanly as I had hoped. So I am offering it up for sale so I can work on building up a SBF to put in its place.
Stock “D9” Block – Cleaned and honed to size by AEM in Salina, KS
Eagle Cast Steel Stroker Crank
H-Beam Rods
Probe 28cc Dished Pistons pistons (10:1 Compression)
Rotating assembly was neutral/internal balanced by AEM
Rings were file fitted and short block assembled at AEM
Jon Kaase Racing oil pump
Canton/Ford Racing oil pan
Ford Racing double roller timing set
New front cover
Ford Racing Water Pump
Innovators West harmonic damper
Jon Kaase spec’d street solid roller cam (Details available to buyer)
Jon Kaase P-51 aluminum heads
ARP Head Studs
Ford Racing Victor single plane intake converted to EFI
Accufab 4bbl Throttle Body
80# Fuel injectors
Jon Kaase sheet metal valve covers
New MSD distributor
Jon Kaase spark plug wires
14” Air cleaner with reusable filter
Engine comes with a pair of Stainless Steel header flanges
Needed to be complete:
Lifters
Pushrods
Rocker Arms
Asking $6500 plus shipping (Engine is located in Salina, KS 67401)
For More Formation, please email me at chris @ candbmotorsports . com
More pictures can be found here:
521" BBF
Also available:
I also have a Quicktime bellhousing that bolts the BBF to an LS based T56 transmission
I have 2 different LT T56 transmissions. Both just need new front cover plates and input shafts to be converted into LS T56 transmissions.
H-Beam Rods
New front cover
ARP Head Studs
80# Fuel injectors
New MSD distributor
Lifters
Pushrods
Rocker Arms
521" BBF
Also available:
Re: 521” BBF - Pump Gas Street Motor
Would you part it out? Might be interested in the intake. What computer were you gonna run?
How much for the quicktime bell?
SLord82- Posts : 145
SLord82 wrote:Would you part it out? Might be interested in the intake. What computer were you gonna run?
Sorry, but I want to sell it complete. The plan was to run the Holley HP EFI system.
The bell is part # RM-8051. I need to dig around and see if I still have all of the bolts for it, but I think I paid nearly $700 for it and I would like to get $500 out of it. Its been bolted to a transmission and put in the car for mockup. The sticker has some discoloring from where the body shop welded in the floor pans above it, but the outside is still glossy and the inside has never seen a clutch.
thats a nice engine
are the heads stock chamber size?the p51 heads are 72 cc unless they make a bigger chamber option.the compression would be close to 12.5 to 1 with a flat top piston.a 29 cc dish would be closer to 10-1.also would you consider selling the long block minus intake,and distributor?
hbstang- Posts : 339
Injected65 wrote:SLord82 wrote:Would you part it out? Might be interested in the intake. What computer were you gonna run?
Sorry, but I want to sell it complete. The plan was to run the Holley HP EFI system.How much for the quicktime bell?
PM sent
hbstang wrote:are the heads stock chamber size?the p51 heads are 72 cc unless they make a bigger chamber option.the compression would be close to 12.5 to 1 with a flat top piston.a 29 cc dish would be closer to 10-1.also would you consider selling the long block minus intake,and distributor?
Sorry about that. I was thinking that they were flat top,but they were dished.
https://performanceparts.ford.com/part/M-6013-521
That is the rotating assembly I had. I bought that and the intake and the oil pan through Lem Evans.
Yes I would be willing to sell the motor minus those parts. Feel free to make me an offer.
Whatever happened with that accessory drive system you have on your webpage?
jasonf- BBF CONTRIBUTOR
It was something I was playing around with at work. I never got around to finishing it. After that picture I went back and started reworking the idler and tensioner placement for better belt wrap but we got busy at work and I never had the chance to finish it.
Engine is sold, but I do still have the intake, fuel injectors and throttle body plus some other parts for sale here.....
https://www.429-460.com/t24915-bbf-460-efi-intake-injectors-throttle-body-bellhousing#286930
» Ford 598 Pump Gas Street / Strip Motor
» What size carburetor for max out street / strip 598ci pump gas motor
» WTB Pump Gas stroker motor or strong pump gas 460
» can you run 11:1 compression on street with pump gas??
» 572 P-51 Pump Gas Street Engine
