93 F150 528cu project build
Page 2 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Re: 93 F150 528cu project build
Post  jones on Mon 7 Dec 2009 - 15:29
I am really trying to decide if I want to pull every bit of wire out of the truck and start re-wiring with a Painless Prostreet wiring harness kit. The kit is on the exspensive side $530 but I an imagine all the other items that will get deleted along with the wiring during the process.
jones
Post  jones on Mon 14 Dec 2009 - 22:09
Just thought I would add this picture.
jones
Post  richter69 on Mon 14 Dec 2009 - 22:13
I'll have to get some pics of that sweet k member and stuff my brother bought from you, saved right at 60#'s
Post  jones on Mon 14 Dec 2009 - 22:45
I was just trying to remember who I sold that stuff too. Wish there was something like that for these things!
jones
Post  sixtynineford on Tue 15 Dec 2009 - 7:46
There is AJE makes kit but pretty expensive, go to NLOC there is several of the trucks with them on them!
sixtynineford
Post  droppedf100 on Wed 23 Dec 2009 - 18:04
We have the a/c and the full stock gauge cluster working on my dads 95 with a carbed 460. It has alot of the original wires still with the harness that goes to the engine chopped down to what we need. Tach, a/c compressor, oil pressure and water temp gauges. Speedo works off the rear but it still has an 8.8. I can get a pic once the snow melts off somewhat.
droppedf100
Post  jones on Sat 26 Dec 2009 - 18:44
Ok, finally the engine is finished, I can now either take it to the dyno or throw into the engine compartment.
Engine overview:
528cu 385 series Ford, Evans Ported Iron cylinder heads, Performer RPM intake, Cartwright camshaft, Adney Rotating Assembly, engine block machine work by Finishline.
jones
Post  jones on Tue 29 Dec 2009 - 19:48
I found a entire front clip off a 95 F150 and went and picked it up today. I'll have to post a picture for kicks & giggles. It's a maroon color but it has the plastic inner fenders, a hood that isn't cut up and a working hood latch!! cheers So I guess I'll remove the old clip before I install the engine.
jones
Post  jones on Fri 22 Jan 2010 - 17:49
Since today is my B-day I figured I'd work on the truck some.
Set the engine in the frame rails for the first time.
Headers don't fit and the 90 degree oil filter adapter won't fit without some notching of the frame.
jones
Post  longroofracer on Fri 22 Jan 2010 - 19:50
Is the header fitment issue something that a small spacer at the bottom of the motor mount would fix?
longroofracer
Post  '65 T-BOLT on Fri 22 Jan 2010 - 22:45
well HAPPY BIRTHDAY Jones!
'65 T-BOLT
Post  jones on Fri 22 Jan 2010 - 23:04
The driver side headers will bolt up but the passanger side needs to tuck-in about 2" and up 2". Don't think a spacer would work, it was a shot in the dark that they would fit since they where made to face the opposite direction in a Mustang.
jones
'65 T-BOLT wrote:well HAPPY BIRTHDAY Jones!
Thanks!
jones
Post  jones on Sun 24 Jan 2010 - 0:44
Whew. all is good now! I invited my brother over and we brainstormed. We ended up taking the motor mounts off and swaping sides. Had to redrill one hole on each mount, by doing this it moved the engine back 1-3/4" and we added two washers under each mount. Now the oil pan, headers and oil filter will fit. I'll post pis tomorrow.
jones
Post  bruno on Sun 24 Jan 2010 - 8:19
its looking good Jones.... it looks like in the pics those headers should work pretty well once you swap those mounts ...... cant wait till its done , its gonna be a sleeper Very Happy
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
