93 F150 528cu project build
Page 5 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Re: 93 F150 528cu project build
Post  jones on Sat 13 Mar - 22:31
I finally got the fuel cell mounted so I could move on to something else. I'll come back later and remove the aluminum tabs that came welded on the fuel cell. use 1/16 x 1" steel for the straps, sanded, primed and painted cast aluminum for now. I place some rubber strips between the straps and fuel cell. The rubber makes the straps bow a little but the fuel cell is tight and not moving. I guess it looks ok. The tank is a Summit 15gal with fuel level sender. I was going to mount it under the bed and use the stock fuel door, but it just hung to low.
jones
Post  '65 T-BOLT on Sat 13 Mar - 22:45
looks good enough to me! I would be happy with that install. Even thou the straps are bowed a little. Maybe could have used 4 little spacers under the factory tabs on the cell and bolted tit to the bed that way! ..just a thought!
'65 T-BOLT
Post  jones on Sat 13 Mar - 22:50
'65 T-BOLT wrote:looks good enough to me! I would be happy with that install. Even thou the straps are bowed a little. Maybe could have used 4 little spacers under the factory tabs on the cell and bolted tit to the bed that way! ..just a thought!
Wouldn't pass tech, plus the tabs are really weak. I would have mounted the straps right over the tabs, but if you notice the return and vent bung is in the way.
jones
Post  '65 T-BOLT on Sat 13 Mar - 22:54
Thanks for the insite! I was not aware that it would not pass tech. I know you said that the tabs are week...but what if you had some 3/4 square tube welded to the frame under the bed? my friend has a 65 stang, square tube chassis and his dad used nut certs in the crossmembers for his cell...car not finished, so not tech'ed
'65 T-BOLT
Post  jones on Sat 13 Mar - 23:14
I figured this would be the easiest and lightest way to do it. I am going to add a aluminum battery box on the rear passanger side. I think that would make it look a little better.
The bed is going to get another paint job or spray in bed liner. I have a handful of holes to weld in the bed floor, but for right now it's done! Very Happy
jones
Post  droppedf100 on Sun 14 Mar - 0:39
Why didnt you just sump the stock rear tank?
droppedf100
Post  jones on Sun 14 Mar - 13:01
Didn't want to mess with it. This has the foam and I don't have to go in circles with buying a new fuel tank then welding up and sealing it.
jones
Post  droppedf100 on Sun 14 Mar - 19:25
I had my stock tank boiled out and had them weld my sump in for 100 bucks a couple years ago. To each his own but for my truck I like to use the stock gas door and I like the bed open.
Did you figure out the wiring yet?
droppedf100
Post  jones on Sun 14 Mar - 19:33
droppedf100 wrote:I had my stock tank boiled out and had them weld my sump in for 100 bucks a couple years ago. To each his own but for my truck I like to use the stock gas door and I like the bed open.
Well this truck didn't come with a gas tank so I had no clue what it would have taken to put one in. I am going to put a soft cover over the bed, battery relocation kit and nitrous bottles.
I gave up on the wiring for now, until I just have to have it done.
jones
Post  bruno on Sun 14 Mar - 19:40
bring the truck to me and we will wire it up Wink
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  '65 T-BOLT on Sun 14 Mar - 20:51
and put a killer sound system it it for you too!
'65 T-BOLT
Post  jones on Sun 14 Mar - 22:23
Don't be joking around, you might ended up with a truck on your property! Laughing
jones
Post  droppedf100 on Wed 17 Mar - 0:26
LOL. Wish you were closer I could give you a hand. Im nowhere near an expert but I have had a ton of 92-96 trucks apart.
droppedf100
nice truck
Post  blown473 on Thu 18 Mar - 19:57
Thats going to be nice when its done! Love the early Lightinings !! I have a gen 2 Lightining, its been a great truck. A big block early model should be a whole lot of fun!!
blown473
Post  jones on Thu 18 Mar - 21:32
Thanks,
jones
