A460 block
A460 block
Post  AndyLeslie on May 16th 2016, 9:34 am
I have an A460 18 head bolt block I'm not going to use for my build.
Currently 4.550 bore could use a clean up hone. I was going to bump it to 4.560 to run a standard off the shelf piston.
Block is in very nice used condition. It has two sleeves in the rear two cylinders. Done very nicely.
This an older block, and has extra material in it that the newer A blocks don't have.
I can text or email pics.
616-325-5571 or Greatlakesracecraft@gmail.com
1500 or best I prefer pick up. I am going to North Carolina next week and to St. Louis in a few weeks so I could drop off in route to either derection.
Located just south of Grand Rapids, Mi
Thanks Andy
AndyLeslie
AndyLeslie
Re: A460 block
Post  AndyLeslie on May 16th 2016, 9:41 am
AndyLeslie
AndyLeslie
Re: A460 block
Post  AndyLeslie on May 16th 2016, 9:42 am
AndyLeslie
AndyLeslie
Re: A460 block
Post  AndyLeslie on May 16th 2016, 9:45 am
Here are the bottom of the sleeves. And all the other cylinders.
That is red wheel bearing grease on everything. The guy I got from coated most all the surfaces with that. So it looks like crap in pictures.
AndyLeslie
AndyLeslie
Re: A460 block
Post  AndyLeslie on May 16th 2016, 9:46 am
AndyLeslie
AndyLeslie
Re: A460 block
Post  AndyLeslie on May 16th 2016, 9:55 am
Interested in trades or partial trades as well. I need a set of 2" big block headers for my 67 mustang. Also need a single plane, dominator intake, a 1150 or bigger dominator. And a set of pistons for a CJ heads, 4.500/6.7 combo 4.390 to 4.440 bores. And a decent solid roller cam.
AndyLeslie
AndyLeslie
Re: A460 block
Post  slurm on May 16th 2016, 8:30 pm
Have set of crites headers of my 67 fastback i want to part with if you are looking to buy used ones.
slurm
slurm
Re: A460 block
Post  AndyLeslie on May 16th 2016, 10:09 pm
I hope to buy those from ya if this hunk of iron sells quick enough!
AndyLeslie
AndyLeslie
Re: A460 block
Post  nuclearcobra on May 22nd 2016, 9:23 pm
I'll take the block Andy , PM sent. Thanks Bryan.
nuclearcobra
nuclearcobra
Re: A460 block
Post  nuclearcobra on May 29th 2016, 6:46 am
Well i gave it a week , So i guess you sold it or changed your mind about selling it maybe ? I was just curious seeing how i called , text and sent you a PM , Anyway hope all is well.
nuclearcobra
nuclearcobra
