1968 1969 Lincoln 460 crank driven power steering pump and extras $500 OBO
This is close to a complete set of what is needed for the 1968 and 1969 Lincoln Mark III and I believe Continental as well. This was on a Mark III that was purchased for the engine. I was planning on using all of the stuff for a project vehicle but I have since decided to remove all of this and use a Saginaw pump instead. When this engine ran a couple years ago the power steering pump worked fine. It was not loud and noisy in any way. I would have to assume that this pump is still in good working order. I would recommend replacing the O-rings in this pump. I have seen these online go for around $30 to $40. I do have the alternator and I have the water pump but was not planning on including it. If it is wanted I can also include it. You will get the timing cover, the power steering pump, two bolts that are specially designed to go through the pump and bolt to the timing cover, the damper / pulley for the crank, the reservoir for the pump, a line that connects to the pump. I believe this line goes around and connects into the manifold somehow rather. You also get the alternator pulley the water pump pulley. I do not have the air conditioning parts. I chose not to paint the timing cover or paint the power steering pump. I chose to leave it all original so you can see as it was when it was removed from engine.
Asking $500 or best to your door.
jruppert- Posts : 34
Re: 1968 1969 Lincoln 460 crank driven power steering pump and extras $500 OBO
Hello Sir,
Is the pump still available and possibly a rebuildable core?
GAFAlamo- Posts : 2
This was sold. Sorry, forgot to update post.
» March aluminum pulley #1810 being used on 68 Lincoln 460 with crank driven power steering
» Power steering pump
» Mustang II power steering pump vs. RPM
» WTB: 429 Power Steering Pump w/bracket
» 69 460 remove power steering pump?
