Making a A460 block Badder!
Page 1 of 5 1, 2, 3, 4, 5  Next
Post  Frank Merkl on July 14th 2016, 2:21 am
Last year we hurt one of our A460 blocks , we run a Ton of nitrous and keep putting are Toes over the edge as you might say !! time to fix it and get back in the game ! This block was our 632 C460 headed motor , melted some pistons . Time for the fix !! Bore from 4.603 to 4.799 for some dimensional 4.801" Ductile Iron sleeves from Darton Sleaves . I did this on my 600 20 years ago and these sleeves are harder than hobo shit !!and hold a ring seal great and you'll wear out the rings long before the cylinder wall. sleeving all 8 holes at the same time makes it so at a later date if and when we burn up a hole real bad we can change the sleeve and not move the cylinders around beside it , the reason I use the sleeve for an AR Ford is the flange mounts nice in the lathe to put a .050" step on the bottom of the sleeve so it can not move ! Gave my ol' triple 7 Van Norman a workout , I don't like to over work it so I only cut .015" at a time which makes for a pile of passes through each hole !! and then leaving the hole and the cutting tool to cool to ambient temp for the final .005-.007" cut to get the crush fit right takes time , I have 2 tool holders with replaceable carbide cutters so it speeds up cool down time .Started 3 pm yesterday on the block and it's ready for the sleeves tonight at 9pm! but time for a beer !
Some pics!
the 3" dia pipe is used as the anchor for the boring bar
the Darton sleeves 4.801" od 4.485 Id so theres more boring going to need to happen to get back to 4.605"and there hard cutting!
Re: Making a A460 block Badder!
Post  BBFTorino on July 14th 2016, 2:47 am
Damn!! you gonna stock up on cutting bits by the truckload?? LOL Very Happy
Post  Frank Merkl on July 14th 2016, 3:25 am
to be honest I cut the all 8 holes from 4.605 to 4.799" on one edge of a new cutter ! ( 6 sided )( 7.5 hrs) now the ductile iron sleeves are a different story as it will take 3 edges to get to the final cut each hole !! from 4.485" to 4.603" with the final hone from 4.603" to 4.605" and it hones hard also!!
Post  Frank Merkl on July 14th 2016, 3:41 am
we'll use up 2 maybe 3 set of stones to get to 4.606" , 2 sets of 280''s and fore sure and a set of 400's maybe 2 ! we hone until my meter says it's right ! and we hand Hone !!! you want to wear out a set of Good Guns ? come Hone with me !
lol
Post  supervel45 on July 14th 2016, 5:09 am
OH'Hell Frank now you pictures ain't working. I clicked on the square box and it did at least go to PhotoBucket but, it did not want to load.
Post  DILLIGASDAVE on July 14th 2016, 6:49 am
supervel45 wrote:OH'Hell Frank now you pictures ain't working. I clicked on the square box and it did at least go to PhotoBucket but, it did not want to load.
Frank's pics show up fine for me.
Maybe it's your computer/internet that's the problem since you have had problems making your pics/links work correctly on this site in the past.
Post  supervel45 on July 14th 2016, 9:08 am
^^^^^^ Could well be.
Post  Frank Merkl on July 14th 2016, 8:33 pm
well 8 sleeves installed ! time to start boring again !
my block heater to get the hole to 200 dregrees
and my propane chiller to get the sleeve to 40 below
Post  68formalGT on July 14th 2016, 8:52 pm
^^^^^Farmer ingenuity!! Nice work Frank.
Post  FalconEh on July 14th 2016, 8:58 pm
Nice..."open headers and smoking prohibited in cold zone" Cool Smile
Post  Lem Evans on July 14th 2016, 9:02 pm
Very Happy
Post  Darrin Gorham on July 14th 2016, 10:42 pm
was that my old block Frank from Tim?
Darrin Gorham
Post  Frank Merkl on July 14th 2016, 11:01 pm
It is the one
Post  BigDave65 on July 15th 2016, 10:38 am
Being an old school machinist this is very cool! Could you rough bore the sleeves in a lathe before installation, to save some time, and wear and tear on your boring machine?
BigDave65
Post  Frank Merkl on July 15th 2016, 11:05 am
I bought the ol' triple "7" Van Norman 40 years ago and it was well used them, but it bores straight and round , just takes time ! The Trick is the operator knows the old girl well!! It's easier to just bore the sleeves in the block
Post  68galaxie on July 15th 2016, 1:19 pm
Very cool!
Frank is this going into the new car body?
Can't wait to see it run when completed.
Cheers
68galaxie
Post  Frank Merkl on July 15th 2016, 4:24 pm
No this goes in the '93 Mustang , the 712 with twin turbo's goes in the new one!
Post  68galaxie on July 15th 2016, 5:45 pm
Wow!!
What size will this one be? I assume the C460 heads and lots of nitrous?
Tell more about the 712 - tall deck block I assume? Iron? aluminum?
What heads? Bore stroke?
What transmission will be used? Don't think a power glide will hold up Smile
Cheers
68galaxie
Post  Frank Merkl on July 15th 2016, 7:20 pm
Here's 2 of the blocks for the New car 11.200" deck aluminum Carrol Carter blocks , bought these off a top alcohol funny car team
Post  Mike R on July 15th 2016, 7:28 pm
Ooooohhhhh, shiney Very Happy Very Happy Very Happy
Post  Frank Merkl on July 15th 2016, 8:17 pm
It will have a Bad Ass C6 behind it!
Post  JBR-3 on July 15th 2016, 8:23 pm
Frank, when you bore to 4.800, have you ever checked remaining wall thickness around the bore at that point ?
Thanks.
JBR-3
Post  Frank Merkl on July 15th 2016, 8:29 pm
never bothered as some holes @ 4.650 were showing porosity and I was rushing the job and never thought about it until the sleeves were in
Post  68galaxie on July 15th 2016, 8:53 pm
Frank Merkl wrote:It will have a Bad Ass C6 behind it!
Very cool!
I like it.
68galaxie
Post  FalconEh on July 15th 2016, 9:06 pm
Awesome Frank, there ain't no melted Toyota's in them blocks.
