Shop Clean out Sale.
I am located in British Columbia Canada but I can arrange to have items shipped from Blaine WA 98230 if you are interested in anything.
DIAMOND PISTONS: 4.600 BORE, 1.250 PIN HEIGHT, .990 PIN, FLAT TOPS NOTCHED FOR C460 HEADS -4.6CC, C/W RINGS BUT NO PINS, A BIT OF WEAR, SKIRTS MIC AT ~4.5925 400.00
DIAMOND PISTONS: 4.530 BORE, 1.250 PIN HEIGHT, .990 PIN, MINI DOMES FOR A460/EX514 HEADS, DECENT SHAPE, WITH PINS AND RINGS, 550.00
OLIVER RODS: 6.800 BBC PATTERN, .990 PINS, REMOVED FROM 7400 RPM 598 AFTER MAYBE 7-800 RUNS?? 300.00
CROWER SPORTSMAN I-BEAM RODS: 6.800 BBC PATTERN, 2-300 RUNS IN 572 @6500RPM 300.00
COMP CAMS ELITE OFFSET BBF LIFTERS: .875 DIA, P/N 98836CR-16, THESE HAVE REPLACEABLE PUSHROD CUPS, CAN BE RUN CENTERED OR OFFSET. USED THREE SEASONS 300.00
CROWER CENTERED BBF ROLLER LIFTERS: P/N 66217H-16, HIPPO OILING, CENTERED CUPS , .875 DIA USED 300.00
COMETIC BBF HEAD GASKETS, .051 THICK, 4.640 BORE, LEM EVANS STEAM HOLES, P/N H1855SPL051S 175/PR.
MSD 8580 DISTRIBUTOR: NEW IN BOX 225.00
460 BBF ¼” ALUMINUM FRONT MOTOR PLATE: 30” WIDE new uncut 100.00
JW WHEEL FLEXPLATE: N93001 CERT EXPIRED CRACKED WELDS REPAIRED 75.00
JW BBF ULTRABELL: CERT EXPIRED sale pending 150.00
ATI SBF DAMPER: P/N 918920, 4 HOLE, CLEVELAND STYLE 300.00
SBF ELITE ROLLER LIFTERS: NEW IN BOX P/N 98838-16 800.00
PAINLESS WIRING SWITCH PANEL KIT: P/N 50302 NEW 300.00
9” FORD PUMPKIN: 1350 YOKE, 4.29 PRO GEARS, STRANGE 35 SPLINE SPOOL, YUKON 3.250 IRON CASE, STRANGE ALUMINUM PINION SUPPORT. sold
AEROSPACE BREATHER TANK WITH FITTINGS AND FILTER NEW P/N AC-BT 100.00
AEROSPACE TALL THERMOSTAT NECK WITH -16 AN FITTING NEW P/N AC-FN5 125.00
bosshoss- BBF CONTRIBUTOR
Re: Shop Clean out Sale.
What's that ultra bell fit powerglide?
fordmonsta- Posts : 230
Sorry, yes. the Ultrabell is for a powerglide.
Dang was hoping it was a turbo 400
