Converted to distributorless ignition!
Page 2 of 2 Previous  1, 2
Re: Converted to distributorless ignition!
Post  SandHillsHillbilly on August 16th 2016, 10:15 am
That is great news. Glad to hear it is working out great for you. Have you done any data logging yet?
SandHillsHillbilly
SandHillsHillbilly
Post  BigBlockRanger on August 16th 2016, 10:58 am
Very little because I only have a few inputs.
I am going to connect the wideband to it this week.
Post  BigBlockRanger on August 30th 2016, 3:42 pm
First trip to the track was a success despite some incoming thunderstorms.  Only got 2 passes in before we bugged out.
Car ran it's best ever et in Amarillo, 10.65 @ 126.4, 1.51' 60' (foot brake).  I didn't check the DA, but can't imagine it was very good considering the baro drops when a storm is approaching. I'd guess it was 5-6000+'. Ignition worked awesome and a semi-hot lap with 2 degrees more timing was a 10.66 @ 126.9.  The second pass was a 1.53 60' with a small lean spike stumble right at the hit.  I think the spike was the result of heat soak because it was similar to what I have experienced using winter blend gas in the summer.  I bought gas at a different station the last time and it was only 90 octane to boot.  Being able to datalog and change ecu settings with my Android phone is FABULOUS.
The rich problem I had turned out to be 2 gummed up air bleeds.  Fixed them before I went to the track.  Connected the MAP and O2 to the MS and was able to get some good data from those 2 runs.
Chassis seems to be working decent. Front tires are just barely coming off the track and the rear seems to stay neutral.
Post  SandHillsHillbilly on August 30th 2016, 4:50 pm
That great news to hear! Are you planning on adding any more sensors to it?
SandHillsHillbilly
SandHillsHillbilly
Post  BigBlockRanger on August 30th 2016, 5:25 pm
Not right now. I think I will just play with it like it is for now.
Post  Mark Miller on August 31st 2016, 12:43 am
2 nice passes and 2 Camaro's on the trailer!!!! Smile Smile Smile
Post  windsor on August 31st 2016, 8:44 am
Looking good. Run down on the engine and driveline combo again?
Post  BigBlockRanger on August 31st 2016, 9:34 am
552
TFS 325's
Herbert CH6H 260/270 DUR@.050, 685/685, 108LC
10.85:1
Holley 1050
Transmission Specialties converter - flashes to 5300
C6
3.90's
Post  BigBlockRanger on September 1st 2016, 12:00 pm
Datalogging is pretty freakin cool.   It's sooooo much easier than trying to watch/remember, etc.
Looks like I have been short shifting 2nd all this time.  I'm only in it for 2 seconds on both runs. I'm in high for a full 5 seconds. That's half the run!
Post  windsor on September 1st 2016, 12:28 pm
Cool. What do you weigh in race trim? Have you calculated HP?
Post  BigBlockRanger on September 1st 2016, 12:38 pm
At the line it is a little over 3400lbs. I have never messed with hp numbers mainly because our DA is so typically awful. It's normally in the 6000 to mid 7000 foot range. It is fun however, to see guys that normally run at sea level come here and wonder why their car is suddenly molasses slow. haha
Post  windsor on September 1st 2016, 12:40 pm
What you run at sea level?
Post  BigBlockRanger on September 1st 2016, 1:00 pm
Idk.  Closest I ever get is Thunder Valley in Noble, Ok.  10.38 @ 131 was the best it ran there last time.  On that trip, the HEI coil was starting to take a dump, getting slower and slower and I wasted my tuning time trying to figure out why it was missing on the top end.  Finally swapped coils and bam went 10.40 @ 130 in the BuickVFord finals with no miss.   The last motor used to drop an easy 0.5 second just from the elevation change.  It only managed to run low 10.90's in Amarillo.
Post  windsor on September 1st 2016, 1:34 pm
Cool. So I assume you're hitting Drag Week again?   Best of luck.  Always follow yours and Bill Fowler's exploits.
Post  BigBlockRanger on September 1st 2016, 2:24 pm
I can't go this year, even though I'm probably more ready than I ever have been. lol
