Rockers and converter
I have a almost new set of comp stanless rockers 1.7 ratio with only dyno time and a BTE 8" 4500 stall with only 4 passes on it, new it was almost 800. i'm asking 400 for the converter and 200 for the rockers, thanks the converter is for a turbo 400 or a glide with a turbo input shaft
Last edited by butterbean on May 21st 2016, 3:03 pm; edited 1 time in total (Reason for editing : added)
butterbean- Posts : 676
Re: Rockers and converter
Where's my valves ButterBean, been two weesk assume no gotty?
supervel45- Posts : 4452
On details on convertor. .need one for my glid3
5pointslow- Posts : 1394
valves
supervel45, I just got back to florida and checked my junk and no valves sorry, 5.slow its got the anti-balloning plate and all the good stuff inside, if you need the part number to look it up I will post it later today when I get back from my shop, Starting to assemble my 600 ci A headed engine today woohoo!!!
I was curious what it was behind ? ....doing an n/a 472 ci
Thanks for Checking ButterBean. Keep your eyes open for some and let me know if you find any. Knew I should have grabbed that Stainless set for 150 but, funds tight as always and only need two valves.
the converter was in a 505 ci pump gas monte carlo with a t-400
PM sent
pm sent
converter sold
Do you still have the rockers and if so what is the part number
Mike R- Posts : 1381
yes, and part number i'll have to get tomorrow
are these the Hi-Tech rockers from comp?
1130 part number 1.73 ratio
or
1120 part number 1.70 ratio (chevrolet big block)
thank you.
chris
or
thank you.
chris
ChrisH- Posts : 149
they are 1120 1.70 and were on A-heads
» 460 tunnel ram, rockers,c-4 bell,c-4 converter,FE Intake,CSR one piece shield for c-6
» 9.5" converter
» tci converter
» wanted c6 converter----roller lifters
» C6 WITH CONVERTER
» 9.5" converter
» tci converter
» C6 WITH CONVERTER
