302/c6 mini starter
302/c6 mini starter
Does anyone know if a starter from a 92F150 302 engine will work with an earlier 302/c6 set up? Or can you recommend a starter that will work?
Re: 302/c6 mini starter
That will work as long as the original trans is an automatic too.
gt350hr- Posts : 662
Ok. I pulled a 302 with a C6 behind it and the starter looks like a mid 80's type (BIG) with the starter gear approximately in the middle. But the 90's 5.0 mini starters have the starter towards the bottom.
This is what the one I took out looks like (looked up 87 Mustang 5.0 starter.
And this is what shows for a 92.
» mini starter
» 460 mini starter
» Mini Starter and OIl Pan Question
» Mini Hi Torque starter
» Help with ford truck mini starter
» 460 mini starter
