AFR Head topic
+20
JBR-3
DaveMcLain
DFI429
gt350hr
5pointslow
Straubtech
Calypso
D. Sea
QtrWarrior
octanehuffer
24 posters
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Re: AFR Head topic
but can they make honey out of horseshit....... I bet they can't even bake a cakeLem Evans wrote:You guys sure can type a lot.
Re: AFR Head topic
Can't we all just get along???
Mike R- Posts : 1381
Re: AFR Head topic
Mike R wrote: Can't we all just get along???
YEA .... certainly
When advice about actual experiences in a situation is openly given for FREE ... "take it or leave it", don't begin a pissing match over it.
Re: AFR Head topic
Advised to hire the job to one of 5 people. Got it. Great advise.
octanehuffer- Posts : 101
Re: AFR Head topic
octanehuffer wrote:Advised to hire the job to one of 5 people. Got it. Great advise.
As has been stated before, That was no ones intent in that post. You just take it that way...
You were all over the map in parts selection and goals for that motor..
The gentlemen that were commenting probably have probably over 100 years combined experience working on BBF's...
The advice you were given was FREE.. Do what you want with it and quit bitchin'....
QtrWarrior- Posts : 2693
Re: AFR Head topic
OK. I switched it around a little by listening to advice. Stock block wasn't going to work. Bought an aftermarket block. Asked another question and based on the advice given, am going with a different head. Advice being given definitely isn't being ignored. If that isn't the intent of a build thread forum, I don't know what is then. Didn't start the thread to question the capabilities of the guy building it for me. I dont care how times a "thread like mine" has been started with poor results. My conclusion probably wont be the same, so dont assume. I have been given several different bores and strokes to use and choose at my discretion. I do not know what stroke best suites me. Nor do I know what bore best suits the head I want to use. I certainly COULD tell my builder to choose and just let it be a surprise. I'm not going to call around and bother a bunch of people just so they can drop what their doing and answer a couple of my measley questions. I don't appreciate it, and I'm willing to bet "pros" don't either.
Re: AFR Head topic
Is this a tech topic?Lem Evans wrote:You guys sure can type a lot.
Scott Foxwell- Posts : 419
Re: AFR Head topic
I still don't understand if your engine builder can't answer these questions...then why are you using him? It's clear you have NO idea what it takes to make 1500#/ft of tq or 2K hp, and I don't say that as a criticism. That's a comprehensive build even for a pro but if your engine builder can't answer the questions and you're left with the "school of opinion" form the internet, I think that's what has people concerned FOR YOU. No one is trying to rain on your parade or just be critical for the fun of it. I think some of us here have seen the signs enough times to know how this USUALLY works out and that's what they're trying to tell you, with all due respect, and no disrespect. You might not think so, but we're on your side.octanehuffer wrote:OK. I switched it around a little by listening to advice. Stock block wasn't going to work. Bought an aftermarket block. Asked another question and based on the advice given, am going with a different head. Advice being given definitely isn't being ignored. If that isn't the intent of a build thread forum, I don't know what is then. Didn't start the thread to question the capabilities of the guy building it for me. I dont care how times a "thread like mine" has been started with poor results. My conclusion probably wont be the same, so dont assume. I have been given several different bores and strokes to use and choose at my discretion. I do not know what stroke best suites me. Nor do I know what bore best suits the head I want to use. I certainly COULD tell my builder to choose and just let it be a surprise. I'm not going to call around and bother a bunch of people just so they can drop what their doing and answer a couple of my measley questions. I don't appreciate it, and I'm willing to bet "pros" don't either.
If you think you and your engine builder got this, that's all that really matters. Thumbs up to you both.
Re: AFR Head topic
Does it have a Radio?
D. Sea- Posts : 2768
Re: AFR Head topic
Scott Foxwell wrote:Is this a tech topic?Lem Evans wrote:You guys sure can type a lot.
For me, typing is very technical.
Re: AFR Head topic
You just can't keep yourself from beginning some kind of altercation ... can you ?
Re: AFR Head topic
I'm not trying to start an altercation as much as I can't get some simple questions answered
Re: AFR Head topic
I know more about typing than 2khp boosted builds, but just to type some tech content here.
After the basic blocks are there, how is the heat and cylinder pressure managed with 2k turbo deal?
-Pistons, structure, pin sizing, ring pack placement, ring materials, clearances?
-Valves, materials, sizing, seat widths, clearances to deal with the heat?
-Do you need coatings to extend life of the components?
-How about the rest of the valvetrain all the way to the cam drive with thoses cyl. pressures?
-Cooling system... Ignition..
I'd be interested in this kind of stuff and would like to get a warm and fuzzy feeling that I don't have to worry about them myself.
Calypso- Posts : 71
Re: AFR Head topic
LOL...Lem Evans wrote:Scott Foxwell wrote:Is this a tech topic?Lem Evans wrote:You guys sure can type a lot.
Re: AFR Head topic
If you have any tips I'd appreciate them, my typing hasn't got any better from when I was in high school
68formalGT- Posts : 862
Re: AFR Head topic
In a build like this you get with one person and follow their advise to the T. In the end if the results don't match the goals you have 1 person to blame and 1 person to hold responsible. You choose your own parts and get advise from 5 people then their are 6 people to blame for failure.
Straubtech- Posts : 293
Re: AFR Head topic
Scott Foxwell wrote:I still don't understand if your engine builder can't answer these questions...then why are you using him? It's clear you have NO idea what it takes to make 1500#/ft of tq or 2K hp, and I don't say that as a criticism. That's a comprehensive build even for a pro but if your engine builder can't answer the questions and you're left with the "school of opinion" form the internet, I think that's what has people concerned FOR YOU. No one is trying to rain on your parade or just be critical for the fun of it. I think some of us here have seen the signs enough times to know how this USUALLY works out and that's what they're trying to tell you, with all due respect, and no disrespect. You might not think so, but we're on your side.octanehuffer wrote:OK. I switched it around a little by listening to advice. Stock block wasn't going to work. Bought an aftermarket block. Asked another question and based on the advice given, am going with a different head. Advice being given definitely isn't being ignored. If that isn't the intent of a build thread forum, I don't know what is then. Didn't start the thread to question the capabilities of the guy building it for me. I dont care how times a "thread like mine" has been started with poor results. My conclusion probably wont be the same, so dont assume. I have been given several different bores and strokes to use and choose at my discretion. I do not know what stroke best suites me. Nor do I know what bore best suits the head I want to use. I certainly COULD tell my builder to choose and just let it be a surprise. I'm not going to call around and bother a bunch of people just so they can drop what their doing and answer a couple of my measley questions. I don't appreciate it, and I'm willing to bet "pros" don't either.
Exactly, If I didn't care, I wouldn't have posted anything. I hate that this pissed you off, and hope all goes well for you.
Re: AFR Head topic
Not pissed one bit. Just disappointed. Off topic.
I spoke with a couple people who had messaged me about the other thread offering actual help and I came to the conclusion of what to do. Ordered a Callies 4.5" crank, Oliver billet rods and Diamond 4.5" pistons. Thank you for those who actually helped! I have ZERO problem helping those who help me. All in all, I got the help I needed and was able to order a bunch of parts. Mission completed. Sad that it went the way it went though.
Re: AFR Head topic
octanehuffer wrote:Not pissed one bit. Just disappointed. Off topic.
Is this still a turbo build?
Re: AFR Head topic
Straubtech wrote:octanehuffer wrote:Not pissed one bit. Just disappointed. Off topic.
Settled on TFS A460 340cc 87cc heads. Going with an all forged setup with Lunati 4.160 crank tool steel pins, diamond pistons Lunati rods.
wasnt this the previous thread of parts ordered ? alot changing
5pointslow- Posts : 1379
Re: AFR Head topic
Im in for 651 hp
Re: AFR Head topic
4.5" stroke with the turbo build?octanehuffer wrote:Not pissed one bit. Just disappointed. Off topic.
Whoever talked you into that didn't do you any favors.
Re: AFR Head topic
Scott Foxwell wrote:4.5" stroke with the turbo build?octanehuffer wrote:Not pissed one bit. Just disappointed. Off topic.
+1 the 4.500 stroke and 20 psi is a bad choice in this application, IMHO. Good luck with getting a dished piston for less than 9-1 compression. 48cc ( approximate) dish is a challenge.
gt350hr- Posts : 662
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» coolant leak between head and block at head bolt location.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» Pondering a new engine build for the jet boat
» Oil filter location, is this going to be an issue?
Page 1 of 4
