A460 blocks
A460 blocks
I believe Lem or someone posted on this before, but I can't seem to find it thru searches.
On the Ford Performance webpage, it lists the M0-6010-A460 block, and the M-6010-A460BB. Looking thru both descriptions of the standard and the big bore specs, they look identically the same, but if I remember correctly, someone posted what the difference was between them.
Thanks in advance.
Thanks in advance.
racnrick- Posts : 462
Re: A460 blocks
racnrick wrote:I believe Lem or someone posted on this before, but I can't seem to find it thru searches.
Thanks in advance.
They ARE identical except the "BB" is bored larger to be honed a minimum of 4.500" bore size.
Re: A460 blocks
Thanks Randy, I looked right over that in the description.
Re: A460 blocks
are you going to order one Rick? I need one also for my dump truck
Darrin Gorham- Posts : 180
Re: A460 blocks
Darrin Gorham wrote:are you going to order one Rick? I need one also for my dump truck
Super Dump
Re: A460 blocks
No, not at this time, I still have the last one I got from Lem about 7-8 years ago, or more, I'm still letting that one "age". Going to put my Boss heads on that block, then will need to get another block for the A460 heads someday, unless you buy them from me.
I had a guy at work ask me what the difference was between the two blocks on Fords website, I look at both and didn't notice the minimum bore on each one, so that's why I asked.
