Prefered VC Gasket
samiam
SLord82
Prefered VC Gasket
Which gasket do most people prefer? The felpro cork or the rubber? This will be for an iron head with a set of Blue Thunder cast aluminum valve covers.
SLord82- Posts : 145
Re: Prefered VC Gasket
SLord82 wrote:Which gasket do most people prefer? The felpro quark or the rubber? This will be for an iron head with a set of Blue Thunder cast aluminum valve covers.
Are the valve cover rails on the heads machined flat or are they as cast ?
Dove heads. I haven't machined the VC rails
I have had better results with the cork
samiam- Posts : 240
As long as they are installed dry and the gaskets are glued to the covers it will make no difference in your application.
DaveMcLain- Posts : 399
DaveMcLain wrote:As long as they are installed dry and the gaskets are glued to the covers it will make no difference in your application.
I ended up doing this with the rubber ones.
If they seal the same I might try the cork ones next time. Had to strech the rubber gaskets to line up right which was a pain
Pay a bit more $$ for the ever reusable ones from 'Earls' products.
They are a rubber coated steel frame that will never crush or leak, and you'll never have to buy VC gaskets ever again!!
BBFTorino- Posts : 984
I have the Cometics on mine and seem to work well after a few heat cycles and cover removals.
jbozzelle- Posts : 3705
