porting A429's
mudtrucker
porting A429's
I have a set of A429's that I bought used with port work already done, going off things that I have seen on here and "the mad porter's" site I cleaned them up a little but have no idea what they flow. I have them on a 466 and I think it runs very well. my question is, is there any one that will do port work on heads that have already been ground on. I have seen on here certain guys have got 380cfm or more out of these heads and that's what id be looking for.
mudtrucker- Posts : 160
Re: porting A429's
mudtrucker wrote:I have a set of A429's that I bought used with port work already done, going off things that I have seen on here and "the mad porter's" site I cleaned them up a little but have no idea what they flow. I have them on a 466 and I think it runs very well. my question is, is there any one that will do port work on heads that have already been ground on. I have seen on here certain guys have got 380cfm or more out of these heads and that's what id be looking for.
There are a number of places who will help them, me included, however, there may be areas where nothing can be machined to help them because there is already metal ground away where it should not be removed. Those areas will not get touched except to be smoothed out a bit.
This may hurt the finished job some.
The valve and seat angles as part of the finished valve job are really important.
Re: porting A429's
you can make pretty good power with a429s
BOSS 429- Posts : 2365
Re: porting A429's
D. Sea wrote:I Like mine
Damon,who ported your A429's?Thanks
Mark Miller- Posts : 1861
Re: porting A429's
Id be glad to do it for you also,but have too much going on right now.Would be a while. rm can prob get them done sooner
Re: porting A429's
Mark Miller wrote:D. Sea wrote:I Like mine
Mark,
Mine were already ported when I got them but I sent them off to Charlie and he tweaked them to make a little more power. This was back in 07 or 08, don't remember exactly.
D. Sea- Posts : 2768
Re: porting A429's
D. Sea wrote:Mark Miller wrote:D. Sea wrote:I Like mine
Mark,
'07....just before the 1st Bash at Windy Hollow?
maverick- BBF CONTRIBUTOR
Re: porting A429's
Mark,
Damon,thanks for the info i would like to have mine ported on someday and build a stroker to.I guess i should start playing the lottery!!!!
Re: porting A429's
I've often thought of selling my top end and going "Bigger" like an A460 setup but it's been working so well... If it aint broke, don't fix it
Re: porting A429's
The A429's seemed to work awesome on my 466 but I spun a rod bearing so it is broke, so I'm building it bigger and better! I'm putting together a 545 with a roller cam instead of the Blake the Snake solid flat tappet ( it will be a custom from Blake). I was thinking of having the A429's worked on, then I thought of selling them and buying a "newer" head like P51's. Then I thought, unless I jump to a A460 head , which will cost a lot more to make the needed changes, I'll just use my A429's as is and see what they will do.D. Sea wrote:I've often thought of selling my top end and going "Bigger" like an A460 setup but it's been working so well... If it aint broke, don't fix it
Re: porting A429's
mudtrucker wrote:The A429's seemed to work awesome on my 466 but I spun a rod bearing so it is broke, so I'm building it bigger and better! I'm putting together a 545 with a roller cam instead of the Blake the Snake solid flat tappet ( it will be a custom from Blake). I was thinking of having the A429's worked on, then I thought of selling them and buying a "newer" head like P51's. Then I thought, unless I jump to a A460 head , which will cost a lot more to make the needed changes, I'll just use my A429's as is and see what they will do.D. Sea wrote:I've often thought of selling my top end and going "Bigger" like an A460 setup but it's been working so well... If it aint broke, don't fix it
Wise choice. My roller was a collective effort from Tree Lem and The Snake. I call it the Albert Clark Barbed Wire Bad Attitude Roller
» SCJ Porting
» scj porting
» head work vs flow?
» Where can ind some baic info on SCJ Kasses head porting?
» Is this adequate gain with the SCJs
» scj porting
