N code 429
+9
jeffgfg
Gary Blair
DFI429
threedwizard
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
N code 429
I'm pulling the engine and trans out of my 1970 Torino Cobra soon to get it ready to detail the engine compartment. I have a small budget for some upgrades, but don't want to tear apart the engine too much. It runs great and has solid compression. I was thinking maybe PI or CJ exhaust manifolds, CJ camshaft and intake. I want the stock appearance, but a little more power. Can the N motor valve springs handle the additional lift?
Any input or suggestions?
threedwizard- Posts : 17
Re: N code 429
threedwizard wrote:I'm pulling the engine and trans out of my 1970 Torino Cobra soon to get it ready to detail the engine compartment. I have a small budget for some upgrades, but don't want to tear apart the engine too much. It runs great and has solid compression. I was thinking maybe PI or CJ exhaust manifolds, CJ camshaft and intake. I want the stock appearance, but a little more power. Can the N motor valve springs handle the additional lift?
The stockk cj/scj cam is not a good enough upgrade to switch to.and you would have to use PI ehx manifolds,because the cj ones have taller ports,and would leak theu the gasket after a while,(unless you welded up the roof of the ehx man.
change the cam,springs,and either the pi's,or headers. you could also work over the intake,or change it,and paint the new one blue
BOSS 429- Posts : 2365
Re: N code 429
I have D3OE-9430-BA exhaust manifolds, D1AE-BA Intake, and D0VE heads. I picked the CJ cam because I don't want to remove the heads. What cam lift can I use with stock valve springs? It's a 4 speed car with 3.25 gears and I'm going for a stock appearing engine compartment in the Torino. Just would like an extra bit of power. If the heads need to come off to change above .505 lift, then I'll save my money and work the heads. I don't want to change block or heads since it's a numbers matching car.
Thanks for any input.
Re: N code 429
This is a numbers matching bigblock Torino Cobra ..and it doesn't already have the CJ parts?
maverick- BBF CONTRIBUTOR
3 different 429's
The Torino Cobra came stock with a 351 Cleveland, then 3 different 429's. N code 360 HP, C code 370 HP CJ, J Code CJ RAM Air. Mine is the Thunder Jet 360 HP. The CJ cam has a little more duration and about .050 lift. I've read it's about 30-35 HP increase. Hope at Stfully someone will chime in on the parts mix. I would like a carb recommend, keep in mind I have a shaker functional hood scoop too.
Thank you again.
Thank you again.
Re: N code 429
lift of the cj cam which is hyd is around .463 (.508) that you see at the valve on avg.with good springs on the ones i have checked
same cam as the scj solid execpt you see more at the valve with the solid of course
Re: N code 429
Thanks Rich, do you think my stock parts mix will work well together? I can check the springs when I assemble the engine, but I'm really trying not to change springs at all. I was wondering if anybody knows what to expect from a stock Thunder Jet valve spring. My M code 351C-4V have a spring that I can use a CJ cam without changing. What carb would work well with this setup? I have a good 4300 Autolite 600 cfm, but I think I can step up a little. The manifold is a speadbore design.
Thanks guys.
Thanks guys.
Re: N code 429
Valve springs get tired with time/use. Especially after close to 50 years and ~ miles.. I used a Comp Dual Energy (275DEH) with my N 429, and their 926-16 springs.. worked very well and made for a fun street ride. Also used studs & roller rockers without any machining other than a fresh valve job. Not sure if it was "perfect", but it worked
Re: N code 429
Just in case you're not aware of it, but you can change out the valve springs without removing the heads.
Re: N code 429
threedwizard wrote:I have D3OE-9430-BA exhaust manifolds, D1AE-BA Intake, and D0VE heads. I picked the CJ cam because I don't want to remove the heads. What cam lift can I use with stock valve springs? It's a 4 speed car with 3.25 gears and I'm going for a stock appearing engine compartment in the Torino. Just would like an extra bit of power. If the heads need to come off to change above .505 lift, then I'll save my money and work the heads. I don't want to change block or heads since it's a numbers matching car.
The drivers side PI exhaust manifold may not clear the steering box. They were designed and used on the full sized cars Galaxie, Custom etc.
Gary Blair- Posts : 221
Re: N code 429
threedwizard wrote:The Torino Cobra came stock with a 351 Cleveland, then 3 different 429's. N code 360 HP, C code 370 HP CJ, J Code CJ RAM Air. Mine is the Thunder Jet 360 HP. The CJ cam has a little more duration and about .050 lift. I've read it's about 30-35 HP increase. Hope at Stfully someone will chime in on the parts mix. I would like a carb recommend, keep in mind I have a shaker functional hood scoop too.
Thank you again.
I learned something already today. Gonna be a good day!
Re: N code 429
I was trying to avoid changing the springs, but it makes sense. Really sucks changing them on the head, I would guess it's a 4 hour job and I need a valve spring press. I need to pick a cam of less than .540 lift to avoid hitting the guides, correct? Also sounds like my manifolds my not work, maybe I can just clean up the stock ones a little?
Any input on using the PI intake? What about the D0OE-9425-C SCJ manifold?
Re: N code 429
Ford did test in their old Parts program that put a SCJ intake on stock heads, and even with the bad port match, it still pick up horsepower and torque over stock. It also allows for more carb options. For a "stock looking" engine I think it would be fine. You also have to be careful of the PI exhaust manifolds with your clutch linkage too. The Torino manifolds and the Mustang manifolds were different on the drivers side. Sounds like a neat project!!! Good luck with it.
jeffgfg- Posts : 338
Re: N code 429
threedwizard wrote:I was trying to avoid changing the springs, but it makes sense. Really sucks changing them on the head, I would guess it's a 4 hour job and I need a valve spring press.
Really sucks?? Probably half that time if you go slow. Especially if your engine is out for bay detailing. Compressed air through the spark plug hole and a simple spring compressor
Re: N code 429
A 600CFM carb is a joke on a 429, hell the cj's came with 780's and that is too small
Re: N code 429
BOSS 429 wrote:A 600CFM carb is a joke on a 429, hell the cj's came with 780's and that is too small
Lol.. back when I first got started with 385s I put together an 800DP Holley from a box of parts and it ran absolutely awesome, with only a slight jet change
Re: N code 429
DFI429 wrote:threedwizard wrote:I was trying to avoid changing the springs, but it makes sense. Really sucks changing them on the head, I would guess it's a 4 hour job and I need a valve spring press.
It's also a good idea to put that piston at TDC just in case you lose air pressure for some reason. If the valve drops down in the cylinder then you'll be pulling the head for sure.
Re: N code 429
Thanks again guys. All good info here. What's the maximum lift you can get away with safely using the Comp Cams Single Spring and Damper? I think I'll try a mild cam with a spilt profile and 110 CL. I'm guessing I'll need the retainer to match? I'll see how the exhaust manifolds pan out, but the intake should fit fine. I agree Rick, the 600 Autolite is a sad carb. What spreadbore do you guys like? I believe I can run a Holley too. I like the Street Avenger in 770.
Great info!!
Great info!!
Re: N code 429
Great info!!
Great info!!
Re: N code 429
If you want to run a square flange Holley I would go with the SCJ intake. The PI intake is kind of a semi speadbore and is supposed to have a square Holley flange bolt pattern. Holley used to make two double pumpers that where semi spread bore with a square flange List# 6708 and 6709 respectively 650 and 750 Cfm. They also made a similar Vacuum Secondary 780Cfm list number 7010, and all had Ford A/T kickdown levers but, they are out of production now. The CJ intake is a full spread bore with it's bolt pattern also, and you are kind of stuck with the Holley QuadraJet replacements if you want to bolt a Holley straight on to one of them.
supervel45- Posts : 4426
Re: N code 429
One other old school method (if you can't use compressed air) was to feed some clothesline type rope into the cylinder through the plug hole, leaving the end hanging out, then gently rotate the engine to press the rope up under the valves. No chance to drop one into the cylinder that way either...but I prefer the air method.
Re: N code 429
maverick wrote:One other old school method (if you can't use compressed air) was to feed some clothesline type rope into the cylinder through the plug hole, leaving the end hanging out, then gently rotate the engine to press the rope up under the valves. No chance to drop one into the cylinder that way either...but I prefer the air method.
Boy you gave away your age with that one, old school for sure, LOL!
One other thing I forgot to mention in my other post, do one cylinder at a time leaving the other spark plugs in and not too much air pressure. Otherwise the engine could roll over on you. Been there and done that.
Re: N code 429
You can get away with a .525" lift, but just like anything else, you better check all the clearances....retainer to valveguide and coil spring clearance at max lift, etc.threedwizard wrote:Thanks again guys. All good info here. What's the maximum lift you can get away with safely using the Comp Cams Single Spring and Damper? I think I'll try a mild cam with a spilt profile and 110 CL. I'm guessing I'll need the retainer to match? I'll see how the exhaust manifolds pan out, but the intake should fit fine. I agree Rick, the 600 Autolite is a sad carb. What spreadbore do you guys like? I believe I can run a Holley too. I like the Street Avenger in 770.
Great info!!
its best to have all matched parts so you're not guessing at compatibility.
BBFTorino- Posts : 982
Re: N code 429
About 27 years ago I installed a Chet Herbert hydraulic cam with .525 lift and 230 duration at .050 into my dads '69 Thunderbird with the Thunderjet 429. He had just done a stock rebuild on it, dropping the compression to 9:1--all new parts including valve springs and rockers but everything was stock, no performance parts. No problems with the valve train. The thing ran great after that. Had a nice rush coming on the cam but was pretty soft on the bottom.
We ended up going with a more street friendly grind after a while. He didn't much care for the whole car shaking at idle at stoplights either.
1EFF100- Posts : 265
Re: N code 429
http://www.jegs.com/i/COMP-Cams/249/34-244-4/10002/-1
I think this is Randy's Comp Cams Shelf Grind. Doubt you will do much better from what you described you wanted. I would still change the valve springs though.
Page 1 of 2 • 1, 2
» 429 partial vin code's?
» Code Scanner
» D6VE CODE =
» Radiator for my 69 fairlane
» G-Code....where art thou??
» Code Scanner
» D6VE CODE =
Page 1 of 2
