Exhaust port trick flows 429-460
dave d
Looking my motor over and found this inside two of my exhaust ports. Everything else looks good on ports . Any ideas Thanks Dave
dave d- Posts : 809
Re: Exhaust port trick flows 429-460
No pics...
jbozzelle- Posts : 3705
Couldn't get picture to load so I changed my profile picture to the exhaust port
dave d- Posts : 809
They turned the ports sideways??
LoL, looks like the port floor has been filled / raised.
BBFTorino- Posts : 982
Valve stem seal issue?
aquartlow- Posts : 167
Haven't taken heads apart to check for any signs. The wet look is not wet and it is only on the two outside exhaust on one bank
dave d- Posts : 809
Could it possibly be an intake gasket sealing issue.
Valve seals leaking
It's fine. Totally normal, and nothing to even think twice about.
Carl- Posts : 284
A few on mine look like that. No biggie unless it's really wet, but then it'll be smoking and noticeable...
finally had a chance to look into it some more and yes the valve seals where stuck the top. Motor is down now for winter time to fix the small things. Thanks everyone for chiming in
dave d- Posts : 809
dave d wrote:Couldn't get picture to load so I changed my profile picture to the exhaust port
Is it dry, kinda dry or slimy ...?
dry hardened, the rest of the exhaust residue will come off somewhat when wiping down
dave d- Posts : 809
» Trick flow Power Port 325's??
» A-460 HEAD QUESTION
» BBF exhaust port header extensions…
» c head exhaust port
» A460 exhaust port
» A460 exhaust port
