Je pistins
Je pistins
Post  fordmonsta on Wed 18 Jan - 15:40
Got a set of je pistons for sale they're 4.44 bore 23.4cc dish for scj head valve reliefs pistons are in exceptional shape will come with all pins and Spiro lox minus 2 think that's missing I'd take 275 shipped
fordmonsta
Re: Je pistins
Post  fordmonsta on Wed 18 Jan - 15:52
1.42 compression height
fordmonsta
Re: Je pistins
Post  Mike R on Wed 18 Jan - 21:33
Stroke?
Re: Je pistins
Post  fordmonsta on Thu 19 Jan - 8:03
I was gonna use em with a 4.500 stroke and a 6.7 rod
fordmonsta
Re: Je pistins
Post  fordmonsta on Thu 19 Jan - 8:25
826058 is the job number from je on the set
fordmonsta
Re: Je pistins
Post  rmcomprandy on Thu 19 Jan - 12:05
fordmonsta wrote:I was gonna use em with a 4.500 stroke and a 6.7 rod
Not with that 1.420" compression distance.
That is the same compression distance as the Ford Racing 514 crate engines with 4.300" stroke and 6.605" rod length.
Could be used with a 4.15" stroke and 6.700" rod length using an older block or decked newer block.
Re: Je pistins
Post  fordmonsta on Thu 19 Jan - 14:08
I was mistaking I meant to say a 4.30 crank doesn't it work like half stroke plus rod length plus pin height gives you deck height or is this wrong
fordmonsta
