Je pistins
Je pistins
Got a set of je pistons for sale they're 4.44 bore 23.4cc dish for scj head valve reliefs pistons are in exceptional shape will come with all pins and Spiro lox minus 2 think that's missing I'd take 275 shipped
fordmonsta- Posts : 222
Re: Je pistins
I was gonna use em with a 4.500 stroke and a 6.7 rod
Re: Je pistins
826058 is the job number from je on the set
Re: Je pistins
fordmonsta wrote:I was gonna use em with a 4.500 stroke and a 6.7 rod
Not with that 1.420" compression distance.
That is the same compression distance as the Ford Racing 514 crate engines with 4.300" stroke and 6.605" rod length.
Could be used with a 4.15" stroke and 6.700" rod length using an older block or decked newer block.
Re: Je pistins
I was mistaking I meant to say a 4.30 crank doesn't it work like half stroke plus rod length plus pin height gives you deck height or is this wrong
