HOWARD'S roller rockers
csdrag
Page 1 of 2
Page 1 of 2 • 1, 2
Any opinions on Howard's roller rockers? Or suggestions for reliable set for .900 lift 7500 RPM engine
csdrag- Posts : 48
Re: HOWARD'S roller rockers
What heads are you running?
TFS AHead
dfree383 wrote:What heads are you running?
csdrag- Posts : 48
csdrag wrote:TFS AHeaddfree383 wrote:What heads are you running?
If your bent on sticking with the stud mound stuff I'd look at either the Crower Stainless Steel stuff or the Comp Cams pro magnum steel ones.
Other than those I'd look into a shaft system.
I have looked at the crower rockers and like them but I haven't priced crower stuff. I will check it out. Wish I could find a used set of shaft rockers for sale. I'm not a fan of stud rockers. At least not in the .750" plus range. I'm just doing this on a budget as does everyone and figuring out how I want to spread the wealth. Unless there is a big difference between in price between shafts and crower stuff I will just buy a shaft setup. Tks for input.
dfree383 wrote:csdrag wrote:TFS AHeaddfree383 wrote:What heads are you running?
csdrag- Posts : 48
Produced/private labeled by Scorpion.csdrag wrote:Any opinions on Howard's roller rockers?
Definitely not the stud rockers from Scorpion. Personally I will use them on flat tappet cammed engines and that's it (ie, no big-springed roller valve trains).csdrag wrote:Or suggestions for reliable set for .900 lift 7500 RPM engine
____________________
Generally speaking, a stud rocker arm system can be suitable and effective on a big springed, high lift cammed engine provided you utilize all the correct and necessary components and the set up is well optimized.
Personally I'd say you could go a long way to re-think your cam. 7500 rpm and .900" lift don't belong in the same sentence.
Scott Foxwell- Posts : 419
csdrag wrote:I have looked at the crower rockers and like them but I haven't priced crower stuff. I will check it out. Wish I could find a used set of shaft rockers for sale. I'm not a fan of stud rockers. At least not in the .750" plus range. I'm just doing this on a budget as does everyone and figuring out how I want to spread the wealth. Unless there is a big difference between in price between shafts and crower stuff I will just buy a shaft setup. Tks for input.dfree383 wrote:csdrag wrote:TFS AHeaddfree383 wrote:What heads are you running?
What kind of valve spring load does your heads have?
If you're going to go .900 lift and 7500+ RPM's, I'd be looking at nothing other than shaft rockers!!
BBFTorino- Posts : 982
BBFTorino wrote:If you're going to go .900 lift and 7500+ RPM's, I'd be looking at nothing other than shaft rockers!!
I suspect he is not.
.850 lift. I am going to look at the crower SS a little harder but I will probably end up putting shafts on it whether I can find a good used set or just buy new. I'm not wild about stud and girdle set ups. They have there place and work fine in their respective applications but I just like a shaft setup. I want others input on the subject though.
csdrag- Posts : 48
irun w&w they set up is very simple and well worth the moneycsdrag wrote:BBFTorino wrote:If you're going to go .900 lift and 7500+ RPM's, I'd be looking at nothing other than shaft rockers!!
tzford- Posts : 24
My 555" Ahead , has Jesel Shaft rockers and has been to 8200
My 615" AHead, Has studs and girdles and has been to 7600-7700..
Both engines over .800' lift
No problems with either...
QtrWarrior- Posts : 2693
QtrWarrior wrote:My 555" Ahead , has Jesel Shaft rockers and has been to 8200
Whose dude rockers and girdle are you running?
csdrag- Posts : 48
Whose stud rockers and girdle are you running?
csdrag- Posts : 48
Are your A460 heads the newer one that take the 1.300" threaded studs on the exhaust side?
Lem Evans wrote:Are your A460 heads the newer one that take the 1.300" threaded studs on the exhaust side?
Lem I just picked them up so I will have to look. I honestly don't know the answer to that. They are 5441t802-m87
csdrag- Posts : 48
csdrag wrote:Lem Evans wrote:Are your A460 heads the newer one that take the 1.300" threaded studs on the exhaust side?
Len I just picked them up so I will have to look. I honestly don't know the answer to that. They are 5441t802-m87
Should have the long studs.....take them out of the box and look at the studs.
csdrag wrote:QtrWarrior wrote:My 555" Ahead , has Jesel Shaft rockers and has been to 8200
Lem can correct me if I'm wrong..
Jomar girdle,( I think) Crower rockers
QtrWarrior wrote:csdrag wrote:QtrWarrior wrote:My 555" Ahead , has Jesel Shaft rockers and has been to 8200
I would put my faith in the Crower arms.
csdrag- Posts : 48
Lem Evans wrote:csdrag wrote:Lem Evans wrote:Are your A460 heads the newer one that take the 1.300" threaded studs on the exhaust side?
I'm still traveling back to my shop so I don't have a caliper with me but hey look like 1.300"
csdrag- Posts : 48
Lem Evans wrote:Sounds right. Do they look like this?
Yes, That's them !!
[quote="Lem Evans"]
Yes they do measure 1.300". What were the older sets? Were they the same as the intakes?
csdrag- Posts : 48
Page 1 of 2 • 1, 2
» Howards solid roller cam and lifters for sale
» QFT Q-series 1050, TFS Trackheat intake, and Howards solid roller cam for sale!!!
» BBF Roller Rockers
» roller rockers
» FOR SALE - COMP CAMS CHROME MOLY ROLLER ROCKERS SOLD SOLD SOLD
» roller rockers
Page 1 of 2
