timing chain oil pump rods roller rockers
jeffgfg
bradsc1954
knrclark
70429scj
Building a budget 460 so used parts are not a problem because this is a temporary build to keep it running and moving
Rods scj eagle i beam or factory with upgraded bolts
Double roller timing chain old style straight up
Roller rockers
Cam and lifters
Oil pump front sump
Aluminum intake dual plane the uglier the better
Cast aluminum valve covers
Rebuildable 750 -850 vacum secondary
NEED SECONDARY METERING BLOCK FOR 3310 CONVERSION IM DOING NOW
valves 2.19 & 1.72
Would condsider a set of used procom heads
Exhaust manifolds mid 70s or somones old short tube headers i can modify
Used is just fine with me
If somebody has a set of used forged pistions for stock or 0.030 bore im interested stock valve layout
Thanks steve
Roller rockers
Cam and lifters
Oil pump front sump
valves 2.19 & 1.72
Thanks steve
70429scj- Posts : 348
Re: timing chain oil pump rods roller rockers
Steve,
I have an intake Victor, oil pump HV and timing chain.
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
I have a brand new set of Lunati solid lifter and have a set push rods. I think I also have a couple valves.
bradsc1954- Posts : 8
I believe I have a set of flat top pistons on SCJ rods supposed to have only dnyo time on them. I will have to check and see if they are forged. If interested.
jeffgfg- Posts : 338
I have a set of used H/S roller rockers.
gt350hr- Posts : 662
I have a set of used eagle SIR rods, they need resizing and new bushings... $140 plus shipping
bluef100fe- Posts : 379
Used Cast Valve Covers
Sir,
I don't know if you ever found a set of factory cast alum valve covers, if not I have a set for you !!!
They are factory 429 ribbed as used on the Torinos & mustangs in 70 & 71. The are not perfect, have been repaired and could need more repairs. I picked them up at a swap meet and did not use. I will sell for $125.00 plus the ride.
Let me know if you're interested.
Text me at (201)852-4267
Thanks, Jay
Thanks, Jay
clevelandcoupe- Posts : 1
I've got a set of rockers they are cam motion 1.73
fordmonsta- Posts : 230
