M-6345-A Stud length concern
M-6345-A Stud length concern Empty M-6345-A Stud length concern
Post  56f100guy February 3rd 2017, 12:25 am
I'm installing a rear pickup tube and am replacing the cap bolt with an M-6345-A stud.
I am very concerned there is not enough thread engagement. The original bolt is about 3.925 under head whereas the stud is 3.475.
With the cap, the stud only threads in what seems only a few revolutions. As I understand, a bolt should be at least as deep as its diameter. There is no way it threads in 1/2".
I would appreciate some advice, i am not comfortable assembling it like that. No way.
Thanks!
56f100guy
M-6345-A Stud length concern Empty Re: M-6345-A Stud length concern
Post  rmcomprandy February 3rd 2017, 12:41 am
56f100guy wrote:I'm installing a rear pickup tube and am replacing the cap bolt with an M-6345-A stud.
Thanks!
If your measurements are correct ... you have the wrong fastener/stud.
Sounds as if it is a 351W main bolt/stud.
Post  56f100guy February 3rd 2017, 1:00 am
Thanks!
It was to my understanding the M-6345-A replaced the C6TZ-6345-A. Is that incorrect?
56f100guy
Post  Doug Rahn February 3rd 2017, 9:50 am
Thanks!
That is incorrect, M-6345-A that is a 302/35W part number. If Lem sees this I'm sure he knows the correct part number and more than likely stocks that part at his dealership.
Okay he does, just saw it in his hard to finds small parts ad. https://www.429-460.com/t2378-hard-to-find-small-parts
Post  Lem Evans February 3rd 2017, 11:55 am
D9HZ-6345-A is the part # for the 429-460 bolt.
Post  56f100guy February 3rd 2017, 4:13 pm
Well, i guess its good news is that i have the correct part number. The bad news is i have a stud i dont need and an engine laying belly up waiting for it.
I knew the correct number(s) , but was told this is the same part. I can tell you...it's NOT.
So..anybody need a 351W stud?!
56f100guy
