Bad luck or bad lifter(s)? Cup came out
STR-LGL-70
SLord82
I was breaking in a new cam in a fresh build and to my horror I could hear a loud ticking after a few minutes of running.
Long story short I pull off the intake and found one lifter with the cup sitting sideways next to the pushrod.
What may have caused this? Bad lifter(s)? Maybe I didn't set the preload correctly? These were new comp hydro lifters. Can is new too. Luckily the cam looks fine and the lifter face looks fine too.
Should I get a new lifter? Or try to put it back together?
SLord82- Posts : 145
Re: Bad luck or bad lifter(s)? Cup came out
I may be wrong,,, but isn't there supposed to an E clip or some sort of snap ring that holds the lifter together?
If there is, did you find it?
Sheldon
Sheldon
STR-LGL-70- Posts : 223
These are comp 832 lifters. They have this wire clip not an E clip
I need a new intake gasket anyway, might as well order a single lifter too for peace of mind.
Anyone have any idea why this may have happened?
preload too loose
BOSS 429- Posts : 2367
BOSS 429 wrote:preload too loose
OR, floating the valve or it sticking in the guide.
rmcomprandy wrote:BOSS 429 wrote:preload too loose
I doubt it floated the valve, it never got over 2k.
Thanks for the feedback guys.
Pushrod too long on that lifter??
BBFTorino- Posts : 984
BBFTorino wrote:Pushrod too long on that lifter??
So just that valve needs a shorter pushrod?
Have you seen it happen before or is this a guess?
I have had that happen to me years ago at the track with my 69 Mustang but I flooted the valves. You might want to check that valve and make sure it not sticking for some reason.
SLord82 wrote:BOSS 429 wrote:preload too loose
about 30 times, that i can rem, very common, just saw a guy I know do this very thing. I told him to put the lifter back together and set the valves right, nows its been fine for a few weeks. how loose were others?
stud mounted rocker?
BOSS 429 wrote:SLord82 wrote:BOSS 429 wrote:preload too loose
Thank you for the feedback.
The other valves were not loose that I noticed, though I accept I may have set one valve incorrectly.
I went ahead and ordered another lifter, it was only 7 bucks and I needed an intake gasket too. I'll recheck the preload on all lifters now.
Adjustable rocker setup, with comp magnum rockers and Manley guide plates on dove heades
» Cam or Lifter Failure....one lifter out of 16 HUGE wear issue (Photo)
» '71 429 cobra jet crankshaft & harmonic Balancer WTB
» Can't believe my luck.
» FOUND 429 CJ oil pump cover only....
» wish me luck
» wish me luck
