7/16 grade 8 cam bolt fine thread ?
whitefield
I was wondering what you guys torque your cam gear bolt to ? bullet solid roller cam with 7/16 x 20 fine thread grade 8. Thanks
whitefield- Posts : 2243
Re: 7/16 grade 8 cam bolt fine thread ?
Dry, plated, grade 8 7/16-20 bolt is 58#. I'd say with a little oil 50-55 is plenty.
Scott Foxwell- Posts : 419
I normally use an alloy rod bolt which torques to 80 pounds. "Double Pinning" an aggressive roller cam can use less.
It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
whitefield wrote:It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
Have you used "red loc-tite" before on a cam and removed? I have found that red loc-tite usually lays a hurt on the fastener or the thread when removed, I usually use the blue, talking the color of the liquid sealer not the tube it comes in.
FalconEh- Posts : 1448
FalconEh wrote:whitefield wrote:It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
Yeah I use loc tite on a,lot of fasteners. I have a loc tite rep that comes and talkes with my students. I take a little butane torch and heat it up and it comes right out.
whitefield wrote:FalconEh wrote:whitefield wrote:It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
Thanks Whitey, I have pulled up a desk...good tip.
A good thick flat washer is a must also. A chevy harmonic balancer washer works great.
I use a grade 10 SHCS torqued to 75 ft lbs.
Lem Evans wrote:"A chevy harmonic balancer washer works great."
SBC
I buy 5 at a time ... and use the ARP hardened alloy, .275" thick washer #200-8717.
The ones directly from Chevrolet and regular parts houses are not hardened but, do work well most of the time.
I get'em a dozen at a time from an outfit in Cali .312" thick looks like this:
I got some here-
https://www.mcmaster.com/#hardened-washers/=16h091d
norm- Posts : 257
» Yoeman and video crew
» D2OE-AB Police Interceptor Ported Heads Flow Chart
» up grade cam for my 545
» 1985 mustang gt roller for sale
» 93 F350 up grade ?
