Boss snout crankshaft
What is the main reason to use boss snout? Ready to purchase new crank but have fluidampner for standard length I'm already using. Also fluidampner is pretty old, do they go bad? Currently running enderle belt drive pump & alternator off of standard length crank.
Thanks!
Sheldon G.
Thanks!
Sheldon G.
STR-LGL-70- Posts : 223
Re: Boss snout crankshaft
throw the fluidampner away! the short snout moves the dampner closer to the front rod throw and takes whip out of the crank on the front rod throw were I've broke 3 cranks over the years . short snout for the last 15 years and no broken cranks
Frank Merkl- Posts : 1524
x10! That pos probably weighs 10#!Frank Merkl wrote:throw the fluidampner away! the short snout moves the dampner closer to the front rod throw and takes whip out of the crank on the front rod throw were I've broke 3 cranks over the years . short snout for the last 15 years and no broken cranks
A lot of engines are even built with a small block length snout, (5/8" shorter yet), in order to be able to use a small block size damper and then not need any spacer at all.
» Going from standard snout to boss snout crank
» Crankshaft snout
» crankshaft front snout lenght
» BBC Damper/snout on BBF
» Boss crank snout.
» Crankshaft snout
» Boss crank snout.
