Delete I found a set
I need a couple stud mounted rocker arms to check piston to valve clearance .I will need the sled fulcrums too .Roller style will work also but I need the 1.73 ratio .Thinking of some new heads for my comet and need to check piston to valve clearance and add valve notches .Thanks Doug in Ga.
Last edited by manofmerc on 4th March 2017, 06:34; edited 1 time in total (Reason for editing : I found a set)
manofmerc- BBF CONTRIBUTOR
» Looking For Gears. Found a set . Delete.
» Delete found item
» please delete item found
» Found what I needed...please delete this thread. Thanks
» Found what I wanted...Admin: Please delete thread
» Delete found item
