429 Fly Wheel
429 Fly Wheel  Empty 429 Fly Wheel
Post  66prostreetfairlane April 9th 2017, 10:19 pm
Hi all,
The family friend that i'm buying the 62 F100 off of has another project he is putting together with the money i'm buying the truck with. The truck should be done in the next 2-3 months and then he will move onto this project. He isn't a big internet guy, so i'm trying to help him out.
We are looking for a 429 Fly Wheel in good condition shipping to zip code 53190. It's a stock 429 that was refreshed.
thanks,
Don
66prostreetfairlane
66prostreetfairlane
https://www.reiautomationsquad.com/
429 Fly Wheel  Empty Re: 429 Fly Wheel
Post  66prostreetfairlane April 12th 2017, 4:12 pm
I don't know a ton about the 429-460 motor or hooking it up to a manual transmission. Am I asking the right question in my initial post about a fly wheel for a stock 429 or is it simply no one has one?
thanks,
Don
66prostreetfairlane
66prostreetfairlane
Post  glenevans April 13th 2017, 7:21 pm
Might have to call an aftermarket clutch company for the flywheel and clutch, should be able to use a 460 or 400 "truck" bellhousing.
glenevans
Post  BOSS 429 April 13th 2017, 11:06 pm
what bell are you going to use?
Post  cool40 April 14th 2017, 12:52 am
I think a 390/FE Bbf flywheel is the same.
Post  66prostreetfairlane April 14th 2017, 1:55 am
BOSS 429 wrote:what bell are you going to use?
Good question and the answer is I don't know, i will call him tomorrow and ask.
66prostreetfairlane
66prostreetfairlane
Post  66prostreetfairlane April 14th 2017, 1:56 am
cool40 wrote:I think a 390/FE Bbf flywheel is the same.
ok ill look into that, thanks!
66prostreetfairlane
66prostreetfairlane
Post  BOSS 429 April 14th 2017, 9:44 am
no, its not. thats why I asked which bell first
Post  cool40 April 14th 2017, 10:19 am
BOSS 429 wrote:no, its not. thats why I asked which bell first
that depends on a few things i suppose. http://www.pirate4x4.com/forum/ford/620003-460-swap-390-flywheel.html
Post  BOSS 429 April 14th 2017, 1:16 pm
some bad/wrong info there i see
Post  cool40 April 14th 2017, 9:27 pm
BOSS 429 wrote:some bad/wrong info there i see
I don't know for sure confused please enlighten us on the subject if you know what does and doesn't work together. study
Post  BOSS 429 April 14th 2017, 11:33 pm
so as not to confuse Im waiting for him to say what bell he has, still
429 Fly Wheel  Empty Flywheel and bell.
Post  blown473 May 23rd 2017, 8:46 pm
You can use a FE 390 manual trans flywheel on a 429 as no 429's were ever externally balanced. You can also used the 390 flywheel on 460's from 1968 to 1978 only, in 1979 to end of production the 460 was externally balanced and requires a different flywheel and the "Hatchet Weight" crank spacer. As for bells you also have several choices, factory 429-460 bells, 351M/400 bells or aftermarket Lakewood (which are no longer in production but available used) or Quicktime which is still in production but very pricey. The easiest to find are the 351M/400 bells which came in trucks and Bronco's and fit nice and have to regular toploader bolt pattern which is also the same pattern as the granny low truck NP435 transmission. The 351M/400 bell also alows the use of the 12 inch truck clutch and of course the normal 11inch or 10.5 inch. Make sure you use the block plate or at least test fit the clutch to make sure it does not hit the inside ribs some bells are cast with (All do not have them) you can spot grind if needed, we have only seen this using Ford "Long " style pressure plates, with a diaphram unit everything clears easily. Hope this info helps.
blown473
blown473
Post  BOSS 429 June 1st 2017, 9:06 pm
390 wheel (184 tooth) will work if you use a 351m or 400 bell, or a scatter shelid (lakewood)
factory 429 flywheels are (176 tooth) ,and then you need factory bell,or again a lakwood< which is why it has 2 starter patterns
same starter for all any of them
