Ring part number
Ring part number
Need part number for rings. 4.3 stroke 6.8 rod .030 over probe forged piston.
away- Posts : 266
PN
This is what I am using mahle (sealed power)315-0010035.This has a low tension oil ring napier second ring moly top and 1/16 thickness .030 oversize .
manofmerc- BBF CONTRIBUTOR
Re: Ring part number
manofmerc wrote:This is what I am using mahle (sealed power)315-0010035.This has a low tension oil ring napier second ring moly top and 1/16 thickness .030 oversize .
Thanks man please refresh my memory apparently I have forgot a lot lol. What does the low tension oil rings do? I'm pretty sure that's what I have been running too. naturally aspirated Alky Injection deal. Also can't find this part number through Jegs.
away- Posts : 266
Call Total Seal and tell them what you need!!
BBFTorino- Posts : 982
rings
Low tension rings reduce friction and the napier second ring has less friction as well and it is a really good oil scraper .Maybe someone more knowledgeable than myself will chime in on this .Here is that pn again 315-0010035.And a # for mahle 888 255 1942 .
A major source of drag ( and "parasitic" horsepower loss) is from piston rings. Oil rings especially. A low drag oil ring has an expander that doesn't create as much drag and frees up some power. "Some" feel this has an effect on oil control in a bad way. The use of a "napier" second ( special undercut for improved oil control) eliminates the potential problem. The result is less rotating friction and more HP.
I would run the above noted ring set for sure.
gt350hr- Posts : 662
Thanks guys
away- Posts : 266
In my search for rings and calling the above number. With alcohol injection naturally aspirated bracket car they recommended a gapless style ring. Have any of you guys ran these rings and what is your opinion of them.
away- Posts : 266
I've ran gapless in a turbo application, and that will be the only thing I'll ever run.
A gaples ring probably won't make any more power but, it will have less oil dilution.away wrote:In my search for rings and calling the above number. With alcohol injection naturally aspirated bracket car they recommended a gapless style ring. Have any of you guys ran these rings and what is your opinion of them.
I would never use a gapless 2nd ring, (except on a part throttle grocery getter engine), however, a gapless top does have some merit with alcohol fuel.
rmcomprandy wrote:A gaples ring probably won't make any more power but, it will have less oil dilution.away wrote:In my search for rings and calling the above number. With alcohol injection naturally aspirated bracket car they recommended a gapless style ring. Have any of you guys ran these rings and what is your opinion of them.
away- Posts : 266
» part number please
» Looking for a part number for these roller rockers?
» Iron heads boss 429 EX part#
» A460 part number
» Part number for L2443 pin Locks?
» A460 part number
