1.83 rockers
1.83 rockers
I now using 1.73 comp gold rockers, what would be pros vs cons of going from 1.73 to 1.8 or 1.83 rockers. Cam is 274 @ .050 .745 lift.
any suggestions on brand and type of rocker?
snuff98- Posts : 245
Re: 1.83 rockers
Never seen a 1.83
You'll gain a slight bit of lift and duration with the higher ratio rockers
Re: 1.83 rockers
Scorpion now offers a 1.83. Never used Scorpion before always Harland Sharp or comp. Just wondering if there would be adverse affects on lifters or valve train in general making the cam seem to have faster opening and closing rates.
Re: 1.83 rockers
Depends on the cam and parts you're using
Only thing adding ratio will tell you if you motor has the right cam or not.
» Converting SBF pedestal mount heads to adjustable rockers... Which length rockers to use???
» 1.6 rockers on a 460. Why?
» 1.72 to 1.8 rockers
» Lots of stuff
» 1.7 Rockers
» Lots of stuff
» 1.7 Rockers
