push rod question
push rod question
I have a question about which push rod is going to have better valve train control and less flex 5/16 .105 thick wall push rod or a 3/8 .080 thick wall push rod ? Spring PSI is 225 seat and close to 700 open . Thanks Whitefield
whitefield- Posts : 2243
Re: push rod question
Both would be about the same strength but flexing the. 3/8 should not flex as bad as the 5/16 because it is bigger around and would support more side loading
» Push rod 5.0 question
» P-51 push rod length- help really dumb question
» Push rod dia?
» 3/8 or 7/16 push rods
» Push rod dia?
