super comp headers primary size question rpm hp limits
70FB
5pointslow
got a set of hooker super comps 2 inch primary 3 1/2 collector foxbody swap headers for $100 today
going to try to see if they fit or make work In the maverick with aje front end .
MY QUESTION
whats the ideal limit for these headers ? i mean i plan on 6500-6800 rpm max and maybe 750 hp tops give or take
i have not posted in a while and been busy finally finished my house ,
i have eddy 61649 Cj heads im using if it matters
either going stock crank with h beams and pistons from carl (14.1) that he sells or somthing similar with these heads ....
was going to use the 4.3 crank i have but think im gonna sell it , seems from what i have read the stock crank is pretty tuff unit and with similar setup heads, solid roller cam and compression . the a 466 vs 528 id imagine wouldnt be night and day ,but i could be wrong
all in all simple footbrake bracket car just wanna get into the 9s
happy to be back on and away from house reno , now i can work on the car and looking forward to chating with you guys
MY QUESTION
5pointslow- Posts : 1400
Re: super comp headers primary size question rpm hp limits
I've made almost 900hp with 2" header
I used the fox body headers in mine with the AJE kit. Had to change two tubes on the drivers side. 2" and 730hp. I'm sure they are probably restricting the motor some.
70FB- BBF CONTRIBUTOR
I have them in my car. I had to slightly flatten one tube on the drivers side where it was hitting the frame. I also use front and mid plates so I had to lower my steering shaft 3" in the firewall to clear my headers.
BigRigTech- Posts : 763
Lowering steering shalf
[quote="BigRigTech"]I have them in my car. I had to slightly flatten one tube on the drivers side where it was hitting the frame. I also use front and mid plates so I had to lower my steering shaft 3" in the firewall to clear my headers.
How did you lower the the steering shalf in the car? Did you cut under the opening and extend the shaft?
mpinder18- Posts : 38
I ran a set in a 86 fox with a D&D K member. 860 HP 6700 RPM peak.
825-ish HP for my 534 with A429 heads on 2" into 3.5" headers.
You'll be fine...
You'll be fine...
D. Sea- Posts : 2768
I dropped the column 3" where it passes through the firewall. I also fabbed some spacers to drop the column down accordingly inside the car. I didn't have to extend the shaft, I used a flaming river shaft kit that was trim as you need it.
