460 bb with 750 dp
460 bb with 750 dp
i bought a 1975 f100 twin cab ...[aussie right hand drive ]with a 460 big block...when I went to view and start it was popping preety bad from the small whelsh plug in the front of the block behind air con motor [on the left hand side]...no water or oil was coming out except air[popping]....or should some fluid of some description be comming out it...can someone tell me is this usual or is there a cracked head..head gasket...or someother explanation..like would the radiator be blocked somehow.....it seems to always run hot to near boiling
effy055- Posts : 3
Re: 460 bb with 750 dp
effy055 wrote:i bought a 1975 f100 twin cab ...[aussie right hand drive ]with a 460 big block...when I went to view and start it was popping preety bad from the small whelsh plug in the front of the block behind air con motor [on the left hand side]...no water or oil was coming out except air[popping]....or should some fluid of some description be comming out it...can someone tell me is this usual or is there a cracked head..head gasket...or someother explanation..like would the radiator be blocked somehow.....it seems to always run hot to near boiling
If it's a plug in the head you're talking about,if so it's probably from the smog pump IIRC and i've had it happen to me years ago?
Mark Miller- Posts : 1861
solution
thanks for the reply ...yes it is in the front of the block on passenger side ... is there a solution to stop it overheating ...IF..this is the cause of it thank you
effy055- Posts : 3
It shouldn't have anything to with the engine overheating IMO unless the timing is off which IIRC is how it happened to me.
This is the only image I could find on the egr crossover tube. It should be your leak but it shouldn't have anything to do with your cooling issue as stated above. You can just make a small plate to cover the holes or put a frost plug in if you can get the right size.
jasonf- BBF CONTRIBUTOR
