Any Difference Between 460 EFI and Carb Blocks
My 86 had a rod let go, I can buy a 97 engine that I know is good. My question is can I strip the 97 down to a shortblock and use the external parts from the 86 on the 97. Like the heads, timing cover, oil pan, and so on.
Also I have a little bigger cam, I don't remember the exact specs but I do know the lift is 480 on both valves. I have heard the EFI valve angles are different so the pistons are different and that valves from D3VE heads may hit. So my question here is can I use the cam from my 86 in the 97.
Thanks for any and all help
plowboy34- Posts : 223
Re: Any Difference Between 460 EFI and Carb Blocks
79 (D9) and up blocks will not fit the earlier factory internal balance cranks.
But all aftermarket stroker kits will fit all blocks.
The later blocks have longer cylinders.
Other than that they interchange
so as long as I use the crank that came with the block I'm good....is this correct
Or an aftermarket stroker crank, the early model cranks will hit the block
thanks dfree
» weiand carb adapter 4500 carb flange to 4150 intake
» Gas carb v/s Alky carb
» wtb a-460 block
» BBF Engine Block That can handle 4.65-4.7 Bore
» I need some help identifying an engine block
» wtb a-460 block
