514 Roller setup Lifter noise
Page 2 of 2 • 1, 2
Re: 514 Roller setup Lifter noise
Do you know if the proper oil gallery plugs are installed in the front oil gallery holes? Those need to be the pointy or tapered head plugs. The front passenger is the critical one though. If you use a flat head plug you can block the oil flow to the lifters... See pics below that I hijacked from Paul Kane's website.
jbozzelle- Posts : 3660
I don't really care what he does to find the problem. There is absolutely NO reason to run 20-50 oil, especially with hydraulics. This is 2017, not 1975.BOSS 429 wrote:OK Shell, Let him run it instead of taking it apart and finding whats really wrong, and adding thinner oil,lolScott Foxwell wrote:BOSS 429 wrote:take the engine apart,something is wrong,and DEFINITELY think about using thinner oil
Scott Foxwell- Posts : 398
OldRed70 wrote:I need some help !!! Got a 514 hydraulic roller setup, new rebuild less than 1000 miles .Engine runs great but lifters sound like they are coming out of the engine. But the noise comes and goes. Oil pressure at idle is 35-38 psi and driving at 3000 rpm oil pressure is 50-55 psi steady.
What I have done to try and fix noise. This is a front sump oil pan.
Installed windage tray
Installed baffles in oil pan
Increased capacity of oil pan to 10 quarts
All internal parts were new when engine was built
Comp cam, lifters, springs, & Comp gold roller rickers
I am at wits end trying to figure this out, I am leaning towards bad lifters...
Any Ideas ???????????????
Increased capacity to 10 qts? How big is this sump? The formula for capacity in qts is Sump Length x Width x Height x .0172 =No. of qts. If your sump capacity is less than 10 qts after you check it with this math you could have a windage issue aerating the oil. Lifters hate aerated oil.
Straubtech- Posts : 293
Here are a couple of pictures of modified oil pan
OldRed70- Posts : 154
Page 2 of 2 • 1, 2
Page 2 of 2
