Small Honda Generator
+6
D. Sea
t-bird racer
10 posters
Small Honda Generator Empty Small Honda Generator
Post  t-bird racer April 25th 2017, 11:15 am
I'm currently looking for a small Honda Generator low noise 2000.  I would like to have one with me up in the staging lanes to run a battery charger.
How big (Watt)  generator is adequate to run 50 amp battery charger?
t-bird racer
t-bird racer
Small Honda Generator Empty Re: Small Honda Generator
Post  Curt April 25th 2017, 1:13 pm
You don't have a 50amp charger, you have a 10 amp charge with a 50amp boost. The 2000 Honda will be perfect.
Post  cool40 April 25th 2017, 2:06 pm
Why the need for charging in the lanes? The little Honda would be perfect.
Post  t-bird racer April 26th 2017, 8:15 am
Well last fall I went to the ford race at MIR.  I entered top and mod, and the way the classes were called to the
lanes there was not much time to charge the battery.  I lost third round in top and made it to 4th round in
mod, which was round robin.  As I cooled down in the lanes, I guess I used all the reserve capacity of the battery
and it would not crank, battery was dead.  I tried the jump box, but it did not have enough.
I missed fourth round due to the battery death.  I was pissed.  I put it on the charger for 5 mins after I missed the round and it fired right up.    I looked at all my time runs and between both classes I made 12 runs on the car.  If I had a little generator and a charger I would have been fine on that day.
Maybe I have to look for a different type battery, however,  The generator and charger during round robin
would be good insurance.
t-bird racer
t-bird racer
Post  D. Sea April 26th 2017, 8:21 am
I have a Honda EU2000i
Weighs just under 50# powers my battery charger as well as trailer lights.
D. Sea
D. Sea
Post  cool40 April 26th 2017, 8:36 am
t-bird racer wrote:Well last fall I went to the ford race at MIR.  I entered top and mod, and the way the classes were called to the
you may think about an alternator also. Idea
Post  maverick April 26th 2017, 12:37 pm
I don't run an alternator....just 2 deep cycle yellow tops wired parallel.  This thing will hot lap with no charger at all, but I use one between rounds just because I can.  I have NEVER had a no-start issue with this setup.
7AL3, electric water pump, fan, trans cooler fan, proStar 500 fuel pump, 2 taillights at night... Wink
Btw, it's connected to a Battery Tender when it sits in the garage, batteries are 7 years old and going strong.
Post  DILLIGASDAVE April 27th 2017, 3:24 am
cool40 wrote:.............you may think about an alternator also. Idea
^^^^This. On a bracket car and/or a car that gets hot-lapped any extra battery help is worth the minor weight penalty an alternator adds, it's good insurance.
Post  Curt April 27th 2017, 8:58 am
I have an extra battery, but it's not in the car. It stays charged in the event that we need it. Only takes a couple of minutes to change it and less if you're in a hurry. It's cheaper than a separate battery charger and generator for the lanes.
Post  dr's wife racing April 30th 2017, 10:04 am
I have used one of the litte hondas for yrs. I mainly use it to to keep my big gen. Off in day time. It will run a batt charger a shop fan with no prob. I t has the built in 12 volt charger but I am on 16 volts. At night i sometimes back feed it into the trailer to run lights and battery charger It will run all day on a tank of fuel. My big gen. Will go thru about 7 to 8 gallons in the same amount of time. I bought mine used at a pawn shop 10 yrs ago and it is still going strong. I would highly reccomend one. Biggest prob. I have with mine is keeping my buddies away from it. They know I two gen.
dr's wife racing
dr's wife racing
Post  t-bird racer April 30th 2017, 12:21 pm
I don't know if a cell went bad in the battery, I do have a small alternator on the car, I have never had a problem with a battery in the last ten years, but, so something is a miss somewhere. I even thought of having a spare battery in the car and just switch the positive cable over in a pinch.
Thanks for your thoughts.
t-bird racer
t-bird racer
Post  paperman May 23rd 2017, 9:54 am
Unfortinatually, the details of AC battery charging mean that many "simple/inexpensive/heavy duty" battery chargers have very poor "Power Factor" which can reduce the apparent generator capacity to 60% or even 50% of name plate rating (the AC Voltage Wave form is a "sine wave"... For many/most AC battery chargers, the current wave form is a a series of current spikes at the peak of the voltage wave form--This causes I2R heating (2x current causes 4x heating losses) of wiring and transformers (and circulating current in transformers--more heating/losses). "Good Power Factor" is around 0.95 to 1.00 or 95% to 100% of rated generator capacity (there are other losses too).
For example, a 1,600 watt Honda eu2000i, the different available battery chargers can output a maximum of:
•1,600 watt * 0.6 PF * 0.80 Efficient charger * 1/14.5 volts = 53 amps maximum @ 12 volts
•1,600 watt * 1.0 PF * 0.80 Efficient charger * 1/14.5 volts = 88 amps maximum @ 12 volts
•1,600 watt * 1.0 PF * 0.90 Efficient charger * 1/14.5 volts = 99 amps maximum @ 12 volts
Still a EU2000 will do what you want and you have it for all those other times you need a but of power and not allot of noise, weight or fuel consumption
paperman
Post  83-88T-Bird Guy May 23rd 2017, 10:59 am
D. Sea wrote:I have a Honda EU2000i
Same here.
It has plenty of power to run my roof top air conditioner on my camper all night.
Just gotta re-fuel every 4 hrs. and 55 minutes.
Because at 5 hours and zero minutes, the little one gallon tank runs out Laughing
83-88T-Bird Guy
83-88T-Bird Guy
Post  83-88T-Bird Guy May 23rd 2017, 11:25 am
The only drawback to the small red Honda generator (other than the small one gallon gas tank) is that thieves love them. If you use a chain or cable to lock it to your trailer, they just hack thru the handle easily and take off with it.
A couple of years ago I made a dual purpose handle guard and exhaust pipe adapter ( to route the fumes thru a stack when parked close to other racers in the pits)
 Small Honda Generator Fnz883
Small Honda Generator I4g0pjSmall Honda Generator 2115jk5
83-88T-Bird Guy
83-88T-Bird Guy
Post  Doug Rahn May 24th 2017, 6:46 am
Although it's on the pricey side, it is another option to secure your generator. Plus they have models to work on a couple different generators. http://lowprolockdown.com
