Starter wiring , with solinoid on starter and fender
+7
gt350hr
rck532
wayney
rocketpony
11 posters
Ok so got new starter which has the solinoid on the starter. The car is fox mustang which has solinoid on the fender.
So will that be ok? Is there anything I gota change?
rocketpony- Posts : 120
Re: Starter wiring , with solinoid on starter and fender
You only need one. Bypass the fender deal.
maverick- BBF CONTRIBUTOR
run the heavy gauge wire from the battery cable side of the solenoid to the starter. this will be hot all the time. run the small wire from the solenoid on the starter to the other large terminal on the original solenoid. where the old starter wire was hooked to.
wayne
wayne
wayney- Posts : 187
wayney wrote:run the heavy gauge wire from the battery cable side of the solenoid to the starter. this will be hot all the time. run the small wire from the solenoid on the starter to the other large terminal on the original solenoid. where the old starter wire was hooked to.
wayne
X2 that way you don't have to run any of the other wires for the charging system and assy to the new starter
Thanks guys, I appreciate the help time and time again
just use a jumper wire from the small wire to the batt wire on the starter
rck532- BBF CONTRIBUTOR
rck532 wrote:just use a jumper wire from the small wire to the batt wire on the starter
Tilton says to do it that way . It does keep the bendix engaged too long as it's still engaged when the engine fires up. Ford wires them like the post from Wayne says. I did my F350 this way using the EFI Ford high torque starter and it is trouble free.
gt350hr- Posts : 662
rocketpony wrote:Ok so got new starter which has the solinoid on the starter. The car is fox mustang which has solinoid on the fender.
So will that be ok? Is there anything I gotta change?
Depending upon WHICH starter combination you now have and its amperage requirements, there are a few different ways it could/should be wired.
If it is a Ford Racing starter then simply move the battery cable on the fender solenoid coming from the starter to the same side as the cable coming from the battery; (the other side from where it is now). Then, run the small 16 gauge wire from the starter combination to the pole on the fender solenoid where that cable used to be.
(As Wayne has already said).
I took battery wire off solenoid and ran to starter.I had jumper on starter.The problem now is I had my power for my msd stuff on same terminal on solenoid as the starter wire now no power for my painless or msd.And we're does the small wire from starter hook to?
bigjohn2007- BBF CONTRIBUTOR
Trying leave solenoid on fenders also for a 12 volt source for accessories.Do I need leave the solenoid on fender or take it off.
wayney wrote: run the heavy gauge wire from the battery cable side of the solenoid to the starter. this will be hot all the time. run the small wire from the solenoid on the starter to the other large terminal on the original solenoid. where the old starter wire was hooked to.
wayne
EXACTLY ...
When I did that the starter engaged time I put battery cable on.What side does the wire from solenoid on starter go on solenoid on the fender?Wud I leave the jumper wire on the solenoid on the starter?
maverick wrote:You only need one. Bypass the fender deal.
Its not a chevy, whats he going to do with the rest of the wires? thats silly
BOSS 429- Posts : 2367
Yes, I use a piece of steel ,< this never fails
I wire back like I had it thru solenoid on firewall.Check the volt on hot side and it was 12.6.Then I check it at starter when I was turning the engine over show 9 volts is this good or should it be higher.I put ground strap on engine to frame and it helped cause it would hardly spin over before.Plus I put new wire and terminals on battery and new ground wire to chassis.I have summit starter on it thinking about going 16 volt battery and better starter.
rmcomprandy wrote:rocketpony wrote:Ok so got new starter which has the solinoid on the starter. The car is fox mustang which has solinoid on the fender.
This is the correct way. If you want your starter to last.
hienergy557- Posts : 179
I guess so on a door car if the battery is up front, but with a long run, I want the hot battery cable to be hot only when starting. JMHO
Curt- Posts : 2787
