Rocker arm?
Mudbogger
Rocker arm?
What rocker arm would be best for for a .900 lift cam and 950# open spring pressure in an iron head, i have a jomar girdle already, i was looking at a crower steel roller rocker arm max rpm maybe 7500
Mudbogger- Posts : 12
Re: Rocker arm?
Thanks. If a shaft mount system was in the budget for it what would you recommend ? Jessel?
Re: Rocker arm?
Nothing wrong with T&D in my experience. Crower is THE best SS rocker out there.
gt350hr- Posts : 662
Re: Rocker arm?
Not Jesel. T&D would be my only choice.Mudbogger wrote:Thanks. If a shaft mount system was in the budget for it what would you recommend ? Jessel?
Scott Foxwell- Posts : 419
Re: Rocker arm?
Mudbogger wrote:What rocker arm would be best for for a .900 lift cam and 950# open spring pressure in an iron head, i have a jomar girdle already, i was looking at a crower steel roller rocker arm max rpm maybe 7500
Harland Sharp for stud mounted, or jessel, or WW for shafts
BOSS 429- Posts : 2367
Re: Rocker arm?
I seen Harlan Sharp has new HD rocker arm for big lifts and high spring pressure
Re: Rocker arm?
they have for quite a while. work great , and are lite compared to SS stuff @ any rpm
Re: Rocker arm?
Price seemed reasonable to , will have to look into them some more
Re: Rocker arm?
As far as those which are currently in production and readily available, the Crower stud rockers--both aluminum and steel--have the best design geometry for their originally-intended cylinder head applications.Mudbogger wrote:What rocker arm would be best for for a .900 lift cam and 950# open spring pressure in an iron head, i have a jomar girdle already, i was looking at a crower steel roller rocker arm max rpm maybe 7500
Given your noted lift and presumed spring pressures, I'd recommend the Crower steel.
Re: Rocker arm?
Thanks for the replies, we'll be using Pac 1248 springs.One more question, builder said bushed roller lifters, any suggestions on which ones to use thanks
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» TNT 3-20-11 *Update 4-4-11 Good News
» Rocker arm roller
» Rocker Studs
» Rocker arm roller
» Rocker Studs
