DOVE block
DOVE block
Went and looked at DOVE block yesterday this one looks different then the usual I've seen, looked like the main webs were wider then usual, its only a 2 bolt main. On the front of the block theirs a square pad that sticks out about a inch and half by inch and half with a big capital letter A, does any one might know what this is?
ctdck- Posts : 49
Re: DOVE block
ctdck wrote:Went and looked at DOVE block yesterday this one looks different then the usual I've seen, looked like the main webs were wider then usual, its only a 2 bolt main. On the front of the block theirs a square pad that sticks out about a inch and half by inch and half with a big capital letter A, does any one might know what this is?
There were many two bolt main D0VE blocks machined for everyday FMC applications which used the Cobra Jet casting cores.
Re: DOVE block
If it has not been severely over bored of cracked I would grab it. I believe the thick web Dove A blocks are the sought after ones people usually want 500 bucks for.
supervel45- Posts : 4426
Re: DOVE block
The main web thickness on all the D0VE blocks I have seen were the same regardless of being a Boss Bulkhead block or standard D0VE block. For more info, click the link below:ctdck wrote:Went and looked at DOVE block yesterday this one looks different then the usual I've seen, looked like the main webs were wider then usual, its only a 2 bolt main. On the front of the block theirs a square pad that sticks out about a inch and half by inch and half with a big capital letter A, does any one might know what this is?
http://www.network54.com/Forum/85220/thread/1351873406
Re: DOVE block
ctdck wrote:a friend told me $ 100
I ll take it if you dont want it
BOSS 429- Posts : 2365
Re: DOVE block
I bought this for a future build, if decide to ever get rid of youll be the first to know.
ctdck- Posts : 49
» DOVE A block
» WTB: Dove-A block or A-460
» DOVE A block
» Dove block
» Big valve ported dove heads ,solid roller camshaft ..$2000 with new studs you pay shipping
» DOVE A block
» Dove block
