spark plugs for 466 with 14 to 1 comp
spark plugs for 466 with 14 to 1 comp Empty spark plugs for 466 with 14 to 1 comp
Post  57ford custom May 24th 2017, 7:16 pm
Hi guys I am looking for a spark plug heat range for my 466 14 to 1 drag car. It has iron cobra jet heads and flat tappet cam and I am looking for an NGK plug heat range number. I use 110 octane in this and the plugs in it now are very old autolite's. I just got it running for this year and it seems to have a little miss so gotta start somewhere.
57ford custom
57ford custom
spark plugs for 466 with 14 to 1 comp Empty Re: spark plugs for 466 with 14 to 1 comp
Post  rmcomprandy May 25th 2017, 12:19 am
57ford custom wrote:Hi guys I am looking for a spark plug heat range for my 466 14 to 1 drag car. It has iron cobra jet heads and flat tappet cam and I am looking for an NGK plug heat range number. I use 110 octane in this and the plugs in it now are very old autolite's. I just got it running for this year and it seems to have a little miss so gotta start somewhere.
IF it is kept below 180 degrees, A 7 or 8 depending upon if it is driving or racing.
spark plugs for 466 with 14 to 1 comp Empty heat range
Post  57ford custom May 25th 2017, 11:40 am
which one is the coldest the A7 or A8
57ford custom
57ford custom
Post  gt350hr May 25th 2017, 12:03 pm
The 8 is colder on NGK plugs. The colder the better with 14-1 on 110 octane.
gt350hr
Post  57ford custom May 25th 2017, 8:14 pm
Thank you I will order a set tomorrow and start with number 8's
57ford custom
57ford custom
Post  460bronco May 25th 2017, 9:07 pm
I'm guessing if his operating temp gets above 180 he would need an even colder heat range?
460bronco
460bronco
spark plugs for 466 with 14 to 1 comp Empty Now where can I find a set of these
Post  57ford custom May 26th 2017, 3:35 pm
My local Autozone is no help so far.
57ford custom
57ford custom
