Found a smoking deal a vortech v2
I found a vortech kit that my brother had on a 4.6 mustang 15 years ago, and the guy that bought it has never used it on anything. I only has 5-7k miles on it and I can buy the kit for $500. I checked with vortech to see if it would work on a 460, a said if building custom brackets to flip it to spin it the correct way. My question is what kind of power potential would yall think could be had with this head unit on a 460 with rods, piston, ported big valve dove heads, custom solid roller, and a blow thru. Also what static compression should I shoot for to be able to turn it up on pump gas? Also would plan on inter cooling it. Below is the blower specs
Performance Specs
Internal Step-Up Ratio: 3.61:1
Max Speed: 52,000 RPM
Max Boost: 22 PSI
Max Flow: 1,150 CFM
Max Power: 775 HP
Peak Efficiency: 78%
Performance specs apply to units equipped with standard gearcase.
Dimensions
Discharge OD: 2.75"
Inlet OD: 3.5"
Discharge ID: 2.38"
Inducer Diameter: 3.1"
Performance Specs
Max Boost: 22 PSI
Max Flow: 1,150 CFM
Max Power: 775 HP
Dimensions
Discharge OD: 2.75"
Inlet OD: 3.5"
Discharge ID: 2.38"
v8ight- Posts : 7
Re: Found a smoking deal a vortech v2
I'm also kinda wondering if this blower is big enough for a 460
v8ight- Posts : 7
Not going to see big boost but will provide something.
I have one of these on my '99 suburban, 350 vortec engine with afterburner headers and 3.5" diesel exhaust. Most boost I have seen is 7 psi (8 on a really good day in the winter). the only boost leak I have is at the throttle shaft and it is a 0.010" leak (according to smoke machine) my pulley ratios are the same as the internal ratio wich puts the supercharger redline at the 6000 engine rpm mark. Works great. not sure what kind of increase you would see in a 460.
83Capri- Posts : 58
