how hot? What thermostat are you running on the street?
Just wondering what the consensus was on thermostat temp for a street driven machine.
83Capri- Posts : 58
Re: how hot? What thermostat are you running on the street?
Assuming you can, running cooler than 180° or so isn't doing your engine any favors. Heat actually helps to cook off condensation in your oil, helping to keep the engine clean. There's a good reason that N.O.T. in newer cars is closer to 200°....a number that used to make us uncomfortable. A cooling system that's up to the task allows you to run hotter SAFELY...but we don't always have one of those.
maverick- BBF CONTRIBUTOR
we dont run a stat in any of our street cars, some have ehx system's that are 15 years old now, NOT rusted thru.
A stats job is to keep and engine hot,not cool it
BOSS 429- Posts : 2367
The reason I ask is I finally have my capri to a point where I'm going to get it plated. I put it together with a 195 t-stat. My electric fan has an adjustable thermostat but my rad is only a 1" single core. and I have 1-2mm between the fan and the water pump pulley. Currently no hood, tuned the carb today had it running for an hour or so roaster the tires a few times and temp was holding steady. Trans has an external cooler and returns through radiator. fan wasn't even hooked up for most of the time I had it running today. sunny day 74degreesF.
83Capri- Posts : 58
High temperature thermostats are for reducing emissions, minimizing engine wear, good fuel economy... and are tolerable with fast burn modern combustion chambers and powerful ecms.
In a high compression, high performance street engine running on crap gas a high temp (195) thermostat invites problems (lowers detonation threshold for a given fuel, loss of power due to charge heating are 2 examples)
In our performance engines I recommend a max of 180 and a good cooling system if static c/r vs cam specs isn't pushing the envelope. A lower temp thermostat makes more power both on the dyno and in the vehicle though any less than about 170 invites a tic more cylinder wall wear. I'll personally take the extra 10 to 20 hp myself.
To the OP. If your combo is edgy run a lower temp stat. If not run a 180 and block the heat through the intake if the passage is present.
S
S
I hadn't even thought about the heat crossover. combo isn't crazy cr is around 9:1 stock cam 106 degree ICL. d0ve heads offenhauser dual port intake. next time I have a good reason to pull the intake off I'll make sure I do that, thanks
83Capri- Posts : 58
» Yes or no to running a thermostat with elec pump drive?
» Running hot with electric pump on street
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» Thermostat or not
» Need Thermostat Housing
» Thermostat or not
