Pistons - 4.440, 4300 strke
Looking for a set of forged domed pistons 4.440 bore, 4.300 stroke that will get me in 15:1 C/R with 75cc heads. What have you got?
Re: Pistons - 4.440, 4300 strke
What heads are you running
fordmonsta- Posts : 230
Ordering the 75 cc 315 AFR's Monday. I am assuming that I can mill on the dome if needed and/or cut valve pockets if needed.
Ive got some brand new icon flat tops but they are for a460 heads would make about 12.5 with a 4.3 stroke
Thanks, trying to get the compression higher that that. This motor will be on alky and alky loves compression...
I have a set of 4.44" Venolia dome tops, I estimate 9-10cc domes, for std valve layout, 1.41" c/h so with a 4.3 stroke you'd use a 6.70"-6.75" aluminum rod depending on your block deck height. I might have a set of rods, too, so if you're interested let me know if pistons only or pistons & rods and I'll see what I can do.HorsinAround wrote:Looking for a set of forged domed pistons 4.440 bore, 4.300 stroke that will get me in 15:1 C/R with 75cc heads. What have you got?
» Looking for Autolite 4300 D0OF-AC - got it thanks
» 4300 Carb Prblems
» rotating ass. push rods msd pistons ''''c-460 pistons added to rotating assembly''''
» ? about my pistons
» 40 over pistons
» 4300 Carb Prblems
» 40 over pistons
